586,058 active members*
4,575 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mitsubishi controls > Mitsubishi meldas mds-r-v1-80 error 12 and 14
    May 2018
    hello,
    Hi, I'm new here, I have a Mitsubishi servo drive that is presenting this error "12 and 54" when it is powered up. Has anyone ever had this problem? Which component in the CPU is faulty?
    Thank you for your help.
    Sep 2017
    139
    Re: Mitsubishi meldas mds-r-v1-80 error 12 and 14
    The drive contol card has to be repaired. It might also cause if signals from power section to control section is mafunctioning.
    May 2018
    Quote Originally Posted by navinbhas View Post
    if I feed only the CPU board already blinks the two errors, 12 and 54. I do not have a card to change, can I fix it? What could be damaged?
  1. Mitsubishi M-60V - Meldas 330M "M01" Error
    By nlh in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-20-2019, 06:13 PM
  2. Mitsubishi Meldas M50 error code S01-0020
    By bocko912 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-26-2017, 08:33 PM
  3. Mitsubishi Meldas M50 error code S01-0020
    By alpercan.06 in forum Uncategorised MetalWorking Machines
    Last Post: 09-17-2010, 09:05 AM
  4. Mitsubishi Meldas error
    By Meldas in forum DNC Problems and Solutions
    Last Post: 07-27-2009, 06:52 AM
  5. M01 Operation Error 0101 on Mitsubishi Meldas M50 control - help!
    By SRT Mike in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-16-2009, 02:33 PM
