586,116 active members*
3,469 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Program milling 22mm keyway.
Results 1 to 6 of 6
    Dec 2017
    5
    Hi I have a Haas vfoe I am wanting to mill a 22mm keyway by roughing and finishing I have tried to use the conversational option of a slot but it will not do it. The keyway is enclosed so will have a rad both sides by chance would anyone be able to write a quick program that I can direct input? It's on the x axis length wise I have tried useing GO3 and an r value without compensation and working it out using 12mm ripper and finisher but I'm not getting a full rad on the ends. Any help greatly appreciated. Thanks
    Oct 2010
    171
    Re: Program milling 22mm keyway.
    More information would make this easier:
    22mm... is that the depth, width, or length? Is it going into a shaft, if so... what diameter? Where do you want the work offsets?
    PM
    Dec 2017
    5
    Quote Originally Posted by precisionmetal View Post
    PM
    Hi thanks for the reply will pm you.
    Oct 2010
    171
    Not sure my private messages are being sent.
    Need more info:
    Total length of the keyway? (extreme end to extreme end).
    Where your origin is? (extreme end of keyway that will be cut, or in the center of the radius on the end of the keyway?)
    9mm deep? Is that in the center of the keyway, or at the outer edges?
    A sketch would be helpful.
    thx
    Oct 2010
    171
    Sent you the code via PM.
    Here is the orientation:
    Oct 2010
    171
    Were you able to cut the keyway?
  1. 2D Milling 2 Setup Program
    By aldepoalo in forum BobCad-Cam
    Last Post: 02-22-2015, 06:02 AM
  2. How to program thread milling?
    By Vegabond in forum G-Code Programing
    Last Post: 08-22-2011, 06:37 PM
  3. make a keyway on milling
    By boudj in forum Canadian Club House
    Last Post: 02-22-2011, 09:13 PM
  4. Need help with thread milling program
    By Lukema in forum G-Code Programing
    Last Post: 10-18-2009, 05:10 PM
  5. Keyway or not to keyway... That is the question
    By jessbussert in forum Stepper Motors / Drives
    Last Post: 12-16-2007, 02:14 PM
