586,058 active members*
4,388 visitors online*
    Feb 2018
    109
    Centrois Linux 2.72 Aux Key question
    I have an Ajax mill with the Linux version of the Centroid control. My Cycle Start button is getting to be in pretty bad shape - this is part of the membrane keypad on the hand held control. Is it possible and practical to program one of the unused keys, like Aux1 to duplicate the the Cycle Start function? Software version is 2.72 and the PLC is the Servo3IO.
    Dan
    Feb 2008
    280
    Re: Centrois Linux 2.72 Aux Key question
    Yes, that is possible. It would be handled in the CPU-based part of your PLC program (the one compiled with plccomp, to cnc10.plc).
    See the "Remote CYCLE START" section of this manual:
    http://www.centroidcnc.com/dealersup...ion/PLCMAN.pdf
    ... but note that a jog panel Aux key will be 0 when idle, and 1 when pressed, so the logic will be a little different.
    At first glance, you might think you could just redefine "Cycle_start" to be INP49 instead of INP75, comparable to what you could do on a CNC11 or CNC12 system. However, that won't work with CNC7 and CNC10: the CPU board "knows" that INP75 is supposed to be Cycle Start, regardless of what names may be given to what location in the PLC program. But the standard remote-start logic referenced in the above manual (and found in many common PLC programs already) will combine another input into INP75, and so will work correctly.
    Feb 2018
    109
    Fantastic! This manual looks like a good addition to my collection for future reference - thanks for the information CNCSNW - looks like I have some reading to do - I'm guessing that I have visited your website for information on this control several times - including the list of compatible motherboards - thanks again for the assistance.
  1. linux question
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 08-10-2016, 11:32 PM
  2. Stupid question- does Pathpilot system restore disc install Linux?
    By Nigel Tufnel in forum Tormach PathPilot™
    Last Post: 04-23-2016, 11:28 PM
  3. new to linux- where exactly is LINUX CNC located in the computer?
    By js412000 in forum LinuxCNC (formerly EMC2)
    Last Post: 03-03-2014, 11:00 PM
  4. CAD and CAM for linux ?
    By bianchi in forum LinuxCNC (formerly EMC2)
    Last Post: 07-16-2012, 10:40 PM
  5. BDI Linux
    By ynneb in forum LinuxCNC (formerly EMC2)
    Last Post: 08-03-2004, 10:38 PM
