586,108 active members*
3,069 visitors online*
Results 1 to 10 of 10
    Feb 2018
    Aluminum plates with countersink holes
    I need 50 of these plates to start with as soon as possible. I should be needing more of these and a couple of different variations soon after. If possible I would like them in a black finish, but I can get them finished locally if it would be too much of a delay. This is a finished part, so I need smooth edges.
    5.15 x .250 in 6061 Aluminum Plate
    .35 in holes and slots
    Holes need countersink to .60 in wide.
    No rough edges (give me options)
    50 parts with more to follow
    Black finish preferred.
    Quote raw & black finish if possible.
    Thank you.
    Sep 2009
    135
    Re: Aluminum plates with countersink holes
    What type of black finish are you referring to? What kind of tolerances do you require?
    G28Machining.com
    [email protected]
    Sent from my SM-G955U using Tapatalk
    Feb 2018
    I’m looking at either a gloss black powder coat or a black anodized finish. I’m open to suggestions.
    Im thinking +/- .005. Its a pretty basic bracket to bolt two parts together.
    Sep 2009
    135
    Ok, I will put a quote together for you.
    May 2015
    23
    Pm Sent.
    Thanks, Matt Mittler
    Mittler Machine Works
    [email protected]
    Cnc Machining | Newmarket | Mittler Machine Works
    PM sent
    Over 30 year in cnc machining parts business.CNC Turning, Milling, Drilling, Planning, Grinding, Welding www.plusminusthree.com Email:[email protected]
    Jan 2008
    60
    PM sent.
    Nov 2011
    10
    PM sent.
    Thanks,*
    Attila*Kovacs*
    Supreme Leader*
    206-669-3524*
    [email protected]*
    3400 N Arizona Ave Ste 110*
    Chandler, AZ 85225*
    Sent from my MHA-L29 using Tapatalk
    May 2018
    PM sent
    Feb 2018
    This job has been awarded. Thanks.
  1. Laser cutter for Aluminum plates and Acrylic plates in one machine
    By Yordanu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-29-2015, 12:20 PM
  2. Help with counterinking on steel plate - Chatter on countersink holes
    By dalianharley in forum Tormach Personal CNC Mill
    Last Post: 06-23-2014, 01:09 AM
  3. Countersink holes
    By glendion in forum EnRoute
    Last Post: 07-17-2012, 04:08 PM
  4. RFQ- Aluminum plates CNC'd
    By revetsp in forum RFQ (Request for Quote)
    Last Post: 05-29-2011, 04:36 PM
  5. RFQ - Two aluminum plates
    By kdoney in forum Employment Opportunity
    Last Post: 09-03-2004, 06:40 PM
