586,060 active members*
3,432 visitors online*
    Oct 2010
    Robofil 440cc help with fault codes
    Hi!
    I got this fault codes on our Robofil 440CC
    1174 UAL Power circuit
    1179 HPF in protection
    1182 HPF
    Does anyone have any idea what the issue could be?
    Best regards Almberg
    Jun 2021
    Re: Robofil 440cc help with fault codes
    Hello Almberg,
    Did you find the reason for the fault codes ?
    Graeme
    Feb 2023
    did you find a solution for your error 1174 ? E1174 ? i have been fighting with that error on my 2007 240cc and need some help
    - - - Updated - - -
    did you get your error 1174 fixed? do you have a solution?
    Feb 2023
    could really use some help on error 1174 guys thanks
    Feb 2023
    any solution to error 1174?
    I had the same error. I check the back plane of the Generator and on the back found 2 electrolytic capacitors. I have been same problem, with a oscilloscope in the output of generator had 32 Khz and was coming down and appear the error again. I was checking power supplies and other. I remove the power transfomer: INPUT: 440VAC, 3phases OUTPUT: 220 VAC, 3 phases and 2 voltages of 60 VAC for each electrode. I bias with 440VAC put resistor load for 30 AMPS in 60VAC the voltage was down to 4 and 6 VAC. The transformer is bad.
    Apppear error 1182, broke the wire, etc. I bought the transfomer (like 3,500 USD in Charmille) I change it and the machine is running very fine wit a good spark plug. GOOD LUCK...
  1. Charmilles Robofil 510 Aux codes
    By tallenttoolroom in forum Waterjet General Topics
    Last Post: 04-27-2020, 09:41 AM
  2. Robofil - Won't Auto-Cut Wire, E735, Threading Motor Fault
    By mflux_gamblej in forum EDM Discussion General Topics
    Last Post: 02-25-2018, 11:21 PM
  3. nc stuido fault codes
    By charlieuk in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-15-2017, 08:39 PM
  4. Robofil 440cc
    By WesO in forum EDM Discussion General Topics
    Last Post: 05-27-2016, 03:09 PM
  5. Fanuc 0T/0M fault codes and Manuals
    By Al_The_Man in forum Fanuc
    Last Post: 11-27-2009, 06:58 PM
