586,115 active members*
3,426 visitors online*
Results 1 to 2 of 2
    May 2018
    Bridgeport 720 Interact (Issue)
    Hi all and thanks for accepting me into the community
    im having an issue with my 720 interact door switch failed and the older gent that used to work on this machine (sadly no longer with us) changed the parameter to make it inactive (the doors can be opened in operation) the HSE wont allow us to run the machine until we fix and reactivate the switch (we have fixed it but have no idea which parameter to change to re enable it) i have the original params list TNC 351/355 just have no idea which 0 to change to a 1 or vice versa to make the door switch active again
    thanks for your time
    Patrick
    May 2006
    60
    Re: Bridgeport 720 Interact (Issue)
    Hello Patrick,
    I believe all you have to do is add 1 to whatever value is in MP158
    The Heidenhain site is a great resource link: https://www.heidenhain.com/en_US/software/
    See attachment for files locations
    Bryan
  1. Bridgeport Interact 412 Fanuc Controller Memory Issue HELP
    By CastleWorks in forum Bridgeport / Hardinge Mills
    Last Post: 08-15-2018, 06:07 PM
  2. Intermittant problem Bridgeport Interact 1 mk2 noise issue - video
    By spookylight in forum Bridgeport / Hardinge Mills
    Last Post: 02-03-2016, 11:36 AM
  3. Bridgeport Series 1 Interact (TNC 145C) - spindle issue - HELP!
    By alexyates in forum Bridgeport / Hardinge Mills
    Last Post: 07-13-2015, 12:56 PM
  4. Bridgeport Interact 412 MPG Issue
    By smirob in forum Bridgeport / Hardinge Mills
    Last Post: 07-15-2008, 02:27 AM
