586,047 active members*
3,614 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Fusion 360 CAM: why doesn`t 4mm cutter fit inside 4mm slot?
Results 1 to 9 of 9
    May 2018
    Fusion 360 seems to require the cutter to be slightly smaller in diameter than the width of the slot. To overcome I have sometimes made the slot slightly wider or the cutter slightly narrower, by 0,01mm. Then it works. Is there any other possibility to overcome this problem?
    Re: Fusion 360 CAM: why doesn`t 4mm cutter fit inside 4mm slot?
    Sketch some lines for the center of your slots, and use the lines for the toolpaths.
    Most CAM software won't allow a slot the same with as the tool. Always model the slots slightly larger.
    Mar 2008
    683
    Double check there is no "stock" offset. Everytime I run toolpaths they default the "leave stock" option for some reason. Other work around is as GER21 says. Draw a slot sketch and drive off the stock. Mathematically there are always tolerances in software that can lead to small issues like this.
    Oct 2010
    171
    One other way to do it is to draw a line for the center of your stock in a sketch, and then use the "Trace" strategy to drive the endmill dead-center along your line. (this may actually be what ger21 is referring to above)
    PM
    Additional.... just made a quick test file. I was unable to cut the slot using the slotting strategy, even when following a sketch line.
    I did, however have prefect results using the Trace strategy. (note that the sketch entity needs to be drawn at the bottom of the slot).
    Here you go.... sample file: -----> https://www.dropbox.com/s/2pddbeoc26..._slot.f3d?dl=0
    PM
    Sep 2009
    1856
    you can always say it's a 3.99999mm endmill
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Jun 2008
    262
    Quote Originally Posted by daniellyall View Post
    Exactly !!! No redrawing necessary.
    i build the braces that keep american teeth straight......tick tick tick
    Jan 2018
    10
    The reason is lead in and lead out. If your drilling a hole, use the bore operation.
    May 2015
    1422
    Stock left (so you can repeat the operation as a finishing cut easily) will do this, as will the lead-in/lead-out, as will too wide a helix radius if you're ramping in for HSM operations.
    Hello, i had the same issue. I fixed it to an unlimmited minium by setting the tolerance in nthe toolpath lower than the additional diameter/distance in the slot/hole.
    You can set the tolerance in the toolpath-settings under "passes".
    hope it helps
    Attached Thumbnails Attached Thumbnails Bildschirmfoto 2021-01-05 um 13.22.59.jpg
  1. My chinese laser cutter won't work at all, software doesn't see the cutter
    By Sasa1234 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-01-2019, 04:09 AM
  2. PathPilot Preview Doesn't Match Fusion 360 Simulation
    By Spiffy Lab in forum Tormach PathPilot™
    Last Post: 08-09-2016, 09:15 PM
  3. T SLOT MILLING CUTTER PACKAGE 5 (ON WALTER CNC CUTTER GRINDER)
    By dharschman in forum Toolgrinding / Toolgrinding Machines
    Last Post: 09-13-2010, 06:25 PM
  4. cutting a slot with a t-slot cutter
    By cncuser1 in forum Mastercam
    Last Post: 09-10-2008, 03:02 AM
  5. How do I use a dove tool cutter & slot cutter
    By bobby1 in forum BobCad-Cam
    Last Post: 04-16-2008, 02:06 AM
