586,117 active members*
3,606 visitors online*
    May 2018
    Ruida Controller Crashed
    I need help with my KH-7050 Chinese laser cutter. Im very new to using this machine and am hoping that somebody out there can help.
    I started my machine this morning and all the settings from the controller are gone the machine starts up and the motors drive the head to the bottom left corner and pushes it past the stops that used to be there.
    I think the vendor settings in rd works is also after resetting itself i have been trying all morning to get it working again (with no help form the supplier) im just lost
    Can somebody who was one of the KH-7050 black and red laser cutter be so kind to send me on the the config setting for my machine
    Best Rergards
    Padraig Hill
    May 2018
    Re: Ruida Controller Crashed
    Hi All,
    Problem is now solved found vendor settings on line which fixed my issue!!!!!
    Oct 2015
    96
    Just in case anyone will have similar issue:
    When machine is starting use ESC key several times. This will avoid "bumping" of the head.
    By the way paudyh - what county you are? +Greetings from west co. Limerick
    Polish @ Éire
  1. replace leetro controller with ruida 6442g
    By Hydrops in forum Laser Control Software
    Last Post: 04-23-2019, 12:21 AM
  2. What is the difference between a Ruida RDC6332G and RDC6442G controller?
    By AdrianPage in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-07-2018, 05:42 PM
  3. Ruida controller and software
    By djmunt in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-28-2017, 05:11 PM
  4. RuiDa CO2 Laser Cutting Engraving Controller RDC6442G
    By nathanhun in forum Want To Buy...Need help!
    Last Post: 12-18-2016, 07:23 PM
  5. PathPilot controller crashed
    By Gerry Kmack in forum Tormach PathPilot™
    Last Post: 04-06-2016, 01:29 PM
