586,071 active members*
3,756 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > just new guy messing around
Results 1 to 2 of 2
    May 2018
    dont know how to navigate this forum stuff .but im trying to build cnc cutter .got every thing hooked up on tb6560 but all stepper does is lock up and cant use manual pad to make it move .any help would be appreciated.
    Dec 2003
    1227
    Re: just new guy messing around
    I have almost exactly the same problem.The machine is ready to be motorised and I have the motors and drivers connected to a DB25 1205 board and a 36 volt power supply.When I test the axes using LinuxCNC,the voltage at the terminals of the board and the drive modules seems to be as expected.Nothing moves though in spite of the feed to the Nema 23's being present.Will I also find that nobody has any suggestions?
  1. Mach3 messing up
    By crafter2u in forum Mach Wizards, Macros, & Addons
    Last Post: 05-24-2014, 01:14 PM
  2. Step messing in CNC 3020 with mach3
    By Mobd3 in forum Mach Software (ArtSoft software)
    Last Post: 04-22-2014, 05:41 PM
  3. Mach 3 is messing up drill toolpaths
    By galaxyman7 in forum Mach Mill
    Last Post: 11-29-2010, 06:00 PM
  4. Assembly without messing up table top
    By yngndrw in forum WoodWorking Topics
    Last Post: 11-29-2009, 08:44 PM
