586,108 active members*
3,287 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Teknic IPC-5 Power Supply - Fan mounting
    I've got a 80mm fan that I'd like to attach to my Teknic IPC-5 power supply.
    They recommend non-conductive hardware. How have other attached a fan???
    Re: Teknic IPC-5 Power Supply - Fan mounting
    Just in case anyone ever comes across this thread, this is what I used to attach the fan to the power supply. Purchased off Amazon.
    May 2005
    3920
    Interesing that they would suggest non conductive hardware. Normal electrical safetydemands that metal parts be boded together to keep everything grounded. Strange to say the least.
    The fan body itself is plastic, likely the reason.
  1. Replies: 1
    Last Post: 01-12-2017, 07:12 AM
  2. Rapid Loss of Cutting Power- New Tube, Fairly New Power Supply
    By scrappyjedi in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 02-23-2016, 01:24 AM
  3. Replies: 15
    Last Post: 10-29-2013, 12:58 AM
  4. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
