586,396 active members*
2,911 visitors online*
Results 1 to 5 of 5
    May 2017
    5
    Help with a driver for Chinese laser cutter
    Hello and thanks in advance , i finally lashed out and decided to buy a laser cutter from china, as you can see below the machine configurations, I am very new to this ans was worried i would not get the support from the buyer once i got it and i am a self learner so everyhting i do will be self taught and trail and error i guess, but I am having trouble at the moment conection the laser cutter to my computer, do i need to install a driver and if so are their websites or drivers that i can downloade for it.
    it did come with a disk but that only had RDworks on it as a program, will i be able to run photoshop or any other prgrams beside RDworks, I will be running it off mylatop and it has windows.
    regards
    Darrin
    Appendix I?Machine Configurations
    Machine Model LM-9060 laser machine
    Laser Tube Power 80-watt
    Working Area 900mm x 600mm
    Packing Standard plywood case for export use
    Machine Color Blue & white
    80W laser tube
    1 piece lens and 3 pieces mirrors installed on machine
    Water chiller-S&A brand CW-3000
    Aluminum blade table
    Honeycomb table
    Up/down table
    Rotary for bottle
    Ruida control system
    Taiwan square linear rail, Japan ONK belt, stepper motor,driver, etc
    Exhaust fan
    Air pump
    Tool box
    User’s manual
    Software in English
    Spare parts:
    Lens: 1 piece
    Mirrors: 3 pieces
    Laser tube: 1 piece
    Voltage 220V, Eu plug
    Jan 2007
    626
    Re: Help with a driver for Chinese laser cutter
    You were right about getting support once you paid your money...its a crap shoot...
    I'm not familiar with that machine, but you will need a software 'plugin' to copy into Mach 3 in order for Mach 3 to 'see' your Motion Card.
    It *should* on the CD, if not you may have open her up and try to identify your particular board. This is an age old problem with Chinese machines.
    OR, the supplier may have provided a link in order for you to download it from.....
    Let us know your situation and we can go from there.
    Another option is to post some clear photos of you Motion Card and someone may recognise it and pipe up.
    You *may* have more than 1 board in your machine, depending on the design. You may have a 'all in one' motor driver board or a separate Driver for each stepper, as well as a Motion Card.
    Prepare to do a lot of reading and coming up against road blocks.....
    May 2017
    5
    Thank you for that i will hav e a look first thing in the morning
    Jan 2009
    72
    Quote Originally Posted by Trin3of7 View Post
    regards
    Darrin
    80W laser tube
    Honeycomb table
    Up/down table
    Rotary for bottle
    Exhaust fan
    Air pump
    Tool box
    User’s manual
    Software in English
    Spare parts:
    Lens: 1 piece
    Mirrors: 3 pieces
    Laser tube: 1 piece
    Darrin
    When you install rdworks it asks if you want to install usb driver and if you want rdworks to pluginto some programs. Use Coreldraw if you can.
    I only purchased the Rudia controller for my home made machine.
    On yours you probably have 2 usb ports 1 is to transfer files to the controller from a usb stick and the other is to connect to your laptop.
    A great site for info is https://rdworkslab.com/ They have a Manual translated from Chinglish to English by the members for download.
    Best of Luck
    Mar 2015
    3
    Watch https://youtu.be/YvrMeUUzaBo and other videos from SarbarMultimedia YouTube channel and You will learn a lot.
    Make sure your machine, laser tube, mirrors are all set properly - there are related videos available on the channel mentioned above.
    Consider LightBurn software, which is compatible with Ruida controllers and I think more intuitive.
    Good luck.
    Wys?ane z mojego SM-G930F przy u?yciu Tapatalka
  1. My chinese laser cutter won't work at all, software doesn't see the cutter
    By Sasa1234 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-01-2019, 04:09 AM
  2. New 60W Chinese Laser Cutter. How thick should it be able to cut?
    By BrendonV in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-31-2017, 08:13 AM
  3. 50w Chinese laser cutter needs help
    By bovegas in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-01-2016, 03:57 PM
  4. 60w Red Chinese Laser Cutter
    By WayneAdams in forum Commercial Laser
    Last Post: 06-30-2016, 08:34 AM
  5. Chinese laser engraver cutter
    By Techie_stephy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-03-2015, 02:03 AM
