586,106 active members*
3,157 visitors online*
Results 1 to 6 of 6
    May 2009
    37
    Migrating from Mach 3
    I wonder if I could tap the collective wisdom here on how I should migrate from Mach 3 please? I've been using M3 for about 8 years now generally successfully, using an old Dell Optiplex computer running XP and driving through the parallel port. I have 3 worries: the machine is old and might crash any time and XP computers with PP are rare and also old; I've written quite a few macros and a new turning offset screen but that isn't finished yet, so there will be some legacy pain; Mach 3 documentation is DIRE and the software seems to be a patch kluge. As I'm about to upgrade my old Win 7 laptop to a new Win10 one I have an option to dedicated the old machine to CNC. So I'm thinking about both software and hardware options and very interested in others' experiences.
    My options seem to be
    1 Switch to a motion controller – this seems to be a given – preferably one that has a parallel port output so it can just plug in to my BoBs on lathe and mill. UC100 looks interesting.
    and…
    2 Mach 3 - but pretty unsupported now and poorly documented and will motion controller plugin support continue? Might be a way in though.
    3 Mach 4 – but why did they choose Lua as a scripting language rather than for example Python? Is the user base big enough for it to survive?
    4 UCCNC
    5 PlanetCNC
    6 Linux CNC – not sure if this supports motion controllers and anyway has a reputation for difficulty in setting up
    7 A dedicated controller – but that may not give me the flexibility I need for example to run my offset setting scripts.
    Any war stories or advice from others who have travelled this route would be most welcome!
    T.I.A.
    John.
    Re: Migrating from Mach 3
    Mach3 development stopped about 5 years ago.
    There are a lot of different motion controllers for Mach3, and you'll find that their plugins don't all support the same features, and don't all support them the same way.
    The ones that function closest to the parallel port are the ESS from Warp9, and any motion controllers from CNC Drive (UC100, UC300ETH, UC400ETH). I know that CNC Drive still peridoically updates their Mach3 plugins, and will fix any reported bugs. This can get tricky, though, because different versions of Mach3 can cause plugins to work differently.
    They apparently feel that Lua was the best option. I think the user base is very small, compared to Mach3. Imo, they are surviving solely on their OEM sales.
    From what I hear, Mach4 is much better than Mach3. But a lot of the choices the developers made have caused a lot of Mach3 users to look elsewhere.
    4 UCCNC
    5 PlanetCNC
    UCCNC is getting very popular with former Mach3 users. Note that it doesn't have a lathe or turn mode.
    I know of a few Planet CNC users that are happy with it.
    Eding CNC is also a good option.
    Linux CNC users will tell you that it's easy to set up. It's not that hard, if you don't mind using Linux.
    Mesa makes Linux CNC motion boards.
    http://store.mesanet.com/index.php?r...tegory&path=83
    May 2009
    37
    Thanks Gerry. A bit further forward...
    Dec 2007
    341
    If your looking for turning ,give Acorn from Centroid a try , i went with them for lathe software and it works well , you get constant surface speed ,spindle encoder feedback tru threading .
    And they just came out with support for shuttle pro express , as well as there wireless remote for jogging and such.
    Just my two cents
    Jan 2010
    30
    I'm in a similar boat.
    I have been using Mach3 with Screenset 2010 on my CNC router. I was recently given an Ethernet SmoothStepper and have a license for Mach4, although I've never used it. I've reconfigured my system to use the Smoothstepper with Mach3, and am looking at what the best next step might be. I haven't stayed very up-to-date on things at Newfangled, but I have to admit I'm a bit shocked how stagnant development has been with Mach4 and the ESS.
    Mach4/Newfangled seem to have turned off a lot of people. I'm not sure how solid the platorm is or what kind of "legs" it has for the future.
    I've heard all good things about UCCNC and the UC motion control boards and wonder if that is where I'll end up, or if Mach4, despite bad press, is a solid solution.
    Dec 2010
    45
    Please include myCNC controllers in your list.
    Attached Thumbnails Attached Thumbnails 15pc-et7r2c-wp2-7k-001.jpg   15PC-ET6-WP2.jpg   et6-a-010.jpg   et15-0kit-top-001.jpg
  1. My experience migrating from Mach3 to UCCNC
    By derek in forum UCCNC Control Software
    Last Post: 09-08-2015, 12:09 AM
  2. Migrating to Sprutcam 9
    By CNC-Dude in forum SprutCAM
    Last Post: 05-18-2015, 07:28 PM
  3. Migrating Mach 2 to Mach 3 settings
    By brian257 in forum Mach Software (ArtSoft software)
    Last Post: 06-10-2014, 02:06 AM
  4. migrating/upgrading Alphacam to new PC
    By nidge in forum Controller & Computer Solutions
    Last Post: 04-24-2011, 10:26 AM
  5. reports folder not migrating
    By coykiesaol in forum Mastercam
    Last Post: 12-07-2010, 07:30 AM
