586,071 active members*
4,022 visitors online*
    Oct 2013
    9
    STB4100 - Mach3 USB Motion Card question
    The circuit below is for the STB4100 - Mach3 USB Motion Card. My question is whether the E-Stop switch, the different limiting switches and the homing switches must be normally open switches (as indicated) or whether they can be normally closed switches?
    I also want to use 3 LJ12a3-4-z/bx Inductive probes for the homing switches. Can anybody advise me how they must be connected please.
    Attachment 393676
    Dec 2017
    26
    Re: STB4100 - Mach3 USB Motion Card question
    from the research i have done its handle by the software : the question i have is how to hook it up i am using a resistor from the 24 volt power source do you have a pic on how you hooked it up?
  1. Mach3 USB Motion Card STB4100 - Best FC300
    By supernichi in forum Mach Lathe
    Last Post: 04-16-2018, 09:58 PM
  2. STB4100 rnr-motion router cnc problem
    By by_yasar in forum Mach Software (ArtSoft software)
    Last Post: 03-24-2017, 02:11 PM
  3. Mach3 USB Motion Card STB4100
    By Poppey in forum Mach Lathe
    Last Post: 01-01-2017, 12:41 PM
  4. Mach3 Motion card XHC 5th MK4-V 4 AXIS mach3 cnc motion control breakout board
    By samnang39 in forum Automation Technology Products
    Last Post: 01-01-2017, 03:22 AM
  5. Mach3 motion card
    By Roctech-Kevin in forum Roctech CNC Routers
    Last Post: 01-30-2015, 07:52 AM
