586,112 active members*
2,999 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 21i T lathe tool offset setting problem
    Oct 2003
    128
    I am having a problem setting the X offset on my machine (a Cincinnati Hawk) . I don't use this machine very often so it is very possible I have forgotten something. The Z seems to work fine.
    At first I thought the problem was limited to 1 position - T1010, now I think it is intermittent. I cannot see a patter.
    Turn a part manually, measure dimension (.656) , enter X.656 in proper row/column , press measure and - the machine calculates the wrong dimension. If I do it again it increments the dimension.
    So I tried it on an empty position (T1212) and it worked as expected. And then tried again and it doesn't. Sometimes it works then not.
    Can this be a battery issue?
    Marc
    Oct 2003
    128
    Re: Fanuc 21i T lathe tool offset setting problem
    Turns out it was a memory problem, my memory. There is an offset/measure button on the membrane keypad that needs to be hit first.
    I knew this, but it has been almost a year since I ran this machine last
    Marc
  1. Tool offset setting
    By yugami in forum Milltronics
    Last Post: 11-06-2018, 03:22 AM
  2. G50 Fanuc 6T Lathe - Tool Setting
    By AZUNIGA in forum G-Code Programing
    Last Post: 07-08-2017, 01:06 PM
  3. V24 lathe tool offset problem
    By newm3 in forum BobCad-Cam
    Last Post: 07-30-2012, 11:18 AM
  4. Offset and tool setting
    By mtnhntr in forum Mori Seiki lathes
    Last Post: 01-10-2011, 03:28 AM
  5. Fanuc 11TT Tool Offset problem
    By Bigbear8291 in forum Fanuc
    Last Post: 02-10-2009, 04:22 PM
