586,058 active members*
4,313 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mitsubishi controls > Mitsubishi Meldas 320 MV spindle orientation problem
    Hello guys,
    I have an older OKK vertical center with Mitsubishi Meldas 320 control.
    From time to time the spindle cannot orient properly and alarm 1027 appears.
    I have opened the covers of the spindle looking for sensors that control the orientation but could not find such.
    I could only locate the pad mounted onto the spindle but no sensor as described on page 16 of the maintenance manual.
    I would appreciate it very much if someone can help.
    Robert
    May 2014
    174
    Re: Mitsubishi Meldas 320 MV spindle orientation problem
    Dear Petroff, What you should be looking for is an ENCODER, a circular shaped component mounted somewhere along the spindle assembly, or in the back of the motor itself. It appears that your encoder could need some service.
    Hello peloflex, thank you very much for the information.
    Robert
    Re: Mitsubishi Meldas 320 MV spindle problem
    Hello peloflex,
    I just got another mysterious problem.
    At the start of the program cycle, after it grabs Tool #1, alarm M01 - 0007 appears, FEED HOLD is activated and the machine goes no further.
    I would appreciate it very much if you can help.
    Robert
  1. Meldas 520AM, Touble with Spindle Orientation
    By CNC Viking in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-24-2024, 10:10 PM
  2. Dnc problem for Mitsubishi Meldas 520AM
    By koeitool in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-11-2022, 07:12 AM
  3. Replies: 1
    Last Post: 12-26-2015, 03:39 PM
  4. Dnc problem for Mitsubishi Meldas 520AM
    By koeitool in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-04-2010, 06:40 PM
  5. Problem in mitsubishi meldas
    By mazman in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-30-2009, 12:36 PM
