586,042 active members*
3,748 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Torchmate > 4800 TorchMate Inch to Metric setting change
    Hi All,
    Trying to get my 4800 machine to operate in metric measurements. Got the movement and display in MMs.
    But IHS doesn't move correctly when set to MM. Really slow down movement of Z axis when sensing with Ohmic shield.
    Secondly, shapes library although dimensions correctly, dimensions greater than 130 mm cannot be entered as error checking
    of required shape is still in inches!
    Any advice greatly appreciated
    Rob
    Aug 2011
    10
    Re: 4800 TorchMate Inch to Metric setting change
    You dont need to make any changes in the VMD software to cut a metric file, in VMD leave everything in inches you can change the Viewport to Metric by Logging on as Admin, click the small Gear icon at top left of the Window on the Units tab change Unit to Metric.
    In the Cad software change your units to Metric by left clicking on the ruler. When you output your file change the Device to read Accumove Millimeter, this is all you need to do to cut a metric file.
  1. UCCNC setting up metric/inch and Diameter/radius
    By bpratl in forum UCCNC Control Software
    Last Post: 08-02-2019, 03:28 AM
  2. How to change SL3A with Fanuc 5T from metric to inch
    By woofa in forum Mori Seiki lathes
    Last Post: 05-27-2016, 02:35 PM
  3. change inch welding measures to metric
    By juha in forum Welding Brazing Soldering Sealing
    Last Post: 06-17-2008, 02:48 PM
  4. change inch welding measures to metric
    By juha in forum Education - Teachers and Students Hangout
    Last Post: 06-17-2008, 04:20 AM
