586,042 active members*
3,685 visitors online*
IndustryArena Forum > CAM Software > Mastercam > unwrap cylinder to engrave on o/d
Results 1 to 6 of 6
    Dec 2006
    58
    Good Day all
    I have lathe with live tooling with a C axis. I can create a cylinder. I am trying to engrave on the o/d of the round stock but am having no joy trying to unwrap the cylinder so that i can put the letters on and then re-wrap. Any suggestions? I have gone thru the Mastercam X getting started guide cover to cover and i have also purchased and gone thru cover to cover the Mastercam X lathe training tutorial. Any help would be a great help. Thank you in advance
    Mar 2005
    461
    Hi Gerry,
    Have you looked into the Xform Roll command and/or the rolldie c-hook ?
    I have never used either but they may help... ?
    Dec 2006
    58
    Hi Matt
    What is the roll die c-hook? I will look into it, Thanks for your time
    Mar 2006
    1013
    This is for Mill, but the principle for lathe is the same.
    It teaches Wrap & UnWrap od wireframe. Indexing work.
    http://www.tipsformanufacturing.com/...ontouring.html
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Mar 2005
    461
    What is a C-Hook ?
    C-Hooks and NET-Hooks are add-in applications or utilities that customize, enhance, or extend Mastercam's functionality. They can be created by individual users, resellers, third-party application developers, or by CNC Software itself. C-Hooks are written in C/C++, while NET-Hooks can be written in major .NET languages such as Visual Basic.NET, C#, or J#. Both are compiled into standalone DLLs and installed in the \Chooks folder in your Mastercam program directory.
    Your Mastercam installation CD includes the necessary resources for you to create your own C-Hooks or NET-Hooks.
    The C-Hook development kit includes all the necessary SDKs and documentation. You can install it separately anywhere on your workstation.
    The NETHook.dll is installed in your Mastercam program directory when you install Mastercam. It contains all the NET-Hook programming resources that your .NET development tool needs.
    The included APIs expose a significant amount of Mastercam's functionality and feature set. In addition, a number of useful C-Hooks are already supplied with Mastercam. Mastercam also provides a number of ways for you to integrate C-Hooks or NET-Hooks into the Mastercam workspace to further customize the interface.
    To run a C-Hook or NET-Hook that hasn't been added to the interface, select Settings, Run User Application from the menu, or press [Alt+C]. Mastercam displays a list of all the C-Hooks and NET-Hooks available on your workstation. Select the desired DLL and click Open.
    Notes:
    You must have the necessary C/C++/.NET programming skills and the proper development tools to compile and link your program. These include Microsoft® Visual Studio®.NET 2003 (version 7.1) or later. These topics are outside the scope of Mastercam and this documentation.
    You can also create scripts using Visual Basic. Mastercam supplies a number of classes and objects for your use, as well as an editor and run-time environment (Settings, VBScript). Unlike NET-Hook DLLs, scripts do not need to be compiled, so their development is simpler.
    What is the Rolldie C-Hook ?
    The Rolldie C-Hook creates toolpaths around a rotary axis. The toolpath can be rounded or squared on outside sharp corners. When a tapered tool is used, the tool can run up and down the crease formed at the intersection of two walls at an inside sharp corner.
    The chained entities selected to create the toolpath can be in the flat or already rolled. Typically this toolpath is used to generate 5-axis tool vectors around a rotary axis, but there is an option to produce a 3-axis toolpath from flat input. This is typically selected for tapered tools.
    In addition to calculating the toolpath, Mastercam also creates the rolled geometry. If you wish, set the geometry color and level before running the C-Hook to organize it.
    Follow these steps to run the C-Hook:
    Open your part file and select the Rolldie C-Hook.
    Chain the contours from which the toolpath is to be generated. They may be either flat or pre-rolled condition.
    Mastercam displays the Toolpath parameters tab, where you can select a tool.
    If you are creating a 5-axis rolled toolpath and the part is not already rolled, select Rotary axis. In the Rotary axis dialog box, select Axis substitution. Set the diameter, rotation direction, and which axis is to be replaced.
    Select the Contour parameters tab and enter your cutting parameters.
    Set Depth to a negative amount and choose Incremental. This sets the depth of the tool tip. If you use a tapered tool, the toolpath will be offset so that the edge of the tapered tool runs on the wrapped or flat chain, resulting in the depth that you have entered.
    Select OK when done.
    Mastercam displays the Rolldie dialog box. Set your RollDie options and click OK to generate the toolpath.
    Hope this helps.
    I copied this from Mastercam's help documents.
    Apr 2003
    3578
    Gerry is this after I sent you the example are you still having issues?
    Jay
    Cadcam
  1. 4 cylinder
    By bluejets in forum I.C. Engines
    Last Post: 07-04-2007, 03:26 PM
  2. Need to engrave on a sphere
    By carbidecraters in forum BobCad-Cam
    Last Post: 07-29-2006, 02:02 PM
  3. Desk Engrave
    By WOODKNACK in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-25-2005, 05:19 PM
  4. How do I engrave numbers...
    By slp_prlzys in forum DIY CNC Router Table Machines
    Last Post: 10-15-2004, 08:35 PM
  5. Replies: 1
    Last Post: 12-29-2003, 02:06 AM
