586,051 active members*
3,638 visitors online*
Results 1 to 8 of 8
    Oct 2016
    5
    Haas SL30 turret problem
    Hi there,I recently had the turret face plate off an SL30 and have re-installed it. Right now it is in between turret positions and gives me alarms so I can't move it. Is there a way I can manually push the turret out and rotate it into the right position? Thanks,Kevin
    May 2018
    69
    Re: Haas SL30 turret problem
    Are you familiar with using macros to do stuff in the machine? You can tell the machine to manually clamp and unclamp the turret. Unfortunately, I dont remember the numbers off the top of my head.
    The process for aligning a turret is fairly intensive especially if you have never done it before. You need to find a maintenance manual that explains it step by step. The turret is actually A axis and needs to be unhidden. Then, you manually job the turret back and forth and read the encoder counts and center it so it locks right up to the coolant nipple.
    This is very broad overview of it. I know 10x the amount of information about working on mills than the lathes. I have done alignments but its been a bunch of years...
    Oct 2016
    5
    Quote Originally Posted by Outlawtaz View Post
    I'll have to get a hold of a manual for the machine and do some reading I guess. Thanks for the reply
    Kevin
    May 2018
    69
    Quote Originally Posted by Palmerston View Post
    Kevin
    Give me the year of your machine. I have some maintenance manuals on CD, I will see if I can copy of few pages out of it and email it to you.
    Oct 2016
    5
    Sent you a PM with my info. Your help is greatly appreciated. Thanks,
    Kevin
    May 2016
    526
    If you go onto the Haas website you can download manuals
    Also you can get the service procesures
    Oct 2016
    5
    Quote Originally Posted by mbservice View Post
    That's great. Thank you
    May 2018
    69
    I will have to second Haas website. I went and looked at the procedure on there and they have updated it since I last did one. The one on the website is a much better (easier) procedure than the original maintenance manual. The original procedure has changing parameters and settings by reading encoder counts which gets into hairy things since you have to run the machine without any electronic stops on it and you can crash the machine if you screw up.
    If you still have problems, let me know and I will go ahead and send you the old procedure.
  1. sl30 turret is lost
    By gregoryblaine in forum Uncategorised MetalWorking Machines
    Last Post: 09-17-2012, 11:29 PM
  2. HAAS SL-20 TURRET PROBLEM HELP
    By allmotormatt in forum Haas Lathes
    Last Post: 01-20-2011, 06:47 AM
  3. Wanted Haas SL30
    By CGreye in forum Want To Buy...Need help!
    Last Post: 08-18-2010, 10:43 PM
  4. Haas SL30 alarm K#-965
    By mgcmn in forum Haas Lathes
    Last Post: 07-18-2010, 03:15 PM
  5. Help with G76 on Haas SL30
    By quadtard in forum Haas Lathes
    Last Post: 08-07-2008, 11:59 PM
