586,103 active members*
3,589 visitors online*
    NVEM 200KHz Ethernet Mach3 Card
    Hi all
    I have NVEM 200KHz Ethernet Mach3 Card and I want to use LinuxCNC, any one could help in this?
    Re: NVEM 200KHz Ethernet Mach3 Card
    Yes. Throw it away and get a Mesa card, as your NVEM card will only work with Mach3.
    Jun 2018
    I can't even get it to work with Mach3
    Aug 2010
    6
    After 8 days I have nearly got my NEVM working, re installed a clean MAch3 setup, rewired my machine to suit pnp not npn inputs and a whole lot of other stuff about 100hrs so far, It works BUT NOT Reliably, NEVM looses ethernet comms regurlarly, (been through PC and adaptor power settings and every other setting) My main problem at this time is the calibration. It changes - Long moves are perpect, 0 - 30 mm randomly loose or gain up to 3 MM way too much.
    Just about had enough of the nvem ad about to throw it in the bit - Chineese DHgate seller very unhelpful and rude
    I wish I had done some more research about these NVEM units I would not buy one again - Has anybody had any success in gettin one to run on Mach3.
    Steve
  1. NVEM Ethernet controller driver
    By GraemeT in forum Controller Cards
    Last Post: 02-10-2019, 10:51 AM
  2. Help with Novusun NVEM USB control card
    By morg769 in forum Controller Cards
    Last Post: 11-13-2018, 11:19 AM
  3. NVEM Ethernet controller custom mpg
    By greekart in forum CNC Machine Related Electronics
    Last Post: 01-11-2018, 07:11 PM
  4. Mach3 / XHC Machmotion Ethernet card slave axis
    By 80gus in forum Mach Software (ArtSoft software)
    Last Post: 05-22-2017, 09:02 PM
