586,076 active members*
3,912 visitors online*
    Mar 2018
    4
    Keystrokes to Enter Heidenhain Parameters
    I have a Bridgeport Interact Series I MKII. I have the parameters and can manually enter them but I don’t know the correct keystrokes to save them and move on. I never get it to switch to English (from German). I have replaced the buffer batteries and it’s easy enough to enter the parameters (although time consuming) but I just can’t figure out how to exit from the parameter screen and have them save. Also, the parameter sheet talks about a “polar” key. What is that?
    I’m hoping someone can help. Thanks for your time.
    Brad from MN
    Mar 2016
    325
    Re: Keystrokes to Enter Heidenhain Parameters
    Polar key is the red P on the numeric keyboard. It's for switching to polar coordinates.
    Feb 2014
    5
    Hi Brad,
    Not sure which controller you have so your mileage might vary. I have the same machine with a TNC 151B controller and, if you are entering your parameters manually, you have to enter all 264 (MP0 - MP263) parameters. When you enter the very last one the controller will automatically bounce out of the parameter screen.
    Hope this helps,
    Les
    Dec 2011
    99
  1. Replies: 23
    Last Post: 07-26-2023, 12:43 PM
  2. Replies: 3
    Last Post: 10-22-2020, 09:20 PM
  3. Replies: 6
    Last Post: 10-29-2012, 11:18 PM
  4. how to enter service parameters?
    By sem in forum Fadal
    Last Post: 02-02-2007, 07:22 PM
