586,035 active members*
3,712 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Joes CNC Model 2006 > My Z axis motor is weak, can move it and stop it under power by hand
    Sep 2015
    9
    Question My Z axis motor is weak, can move it and stop it under power by hand
    Running Mach3 on a XZero Raptor with Nema 23's -Smooth Stepper (ethernet) and Leadshine Mx3660 driver. The X and Y axis are so strong I can't stop them when under power, can't move them at all with machine on, however the z axis is weak, losing steps on lift actions, and I can move it by hand when stopped and when moving. What would cause it to be under powered? I've checked wiring, motor tuning in Mach3, and checked for gantry binding, nothing seems amiss. Bad driver? Bad motor, how to test? Any advice is appreciated.
    Re: My Z axis motor is weak, can move it and stop it under power by hand
    Switch the Z stepper onto the X or Y driver and see how it does then. Also plug X or Y into the Z and see how they perform.
    Sep 2015
    9
    Thank you, I've done so, I placed Z motor plug on the Y driver and visa versa, the Z axis was still weak. That indicates the motor as the culprit right? How do I test motor? or should I just order another asap? Thank you
    Mar 2007
    2083
    If you swapped the plugs at the control box and still have a Z axis motor fault
    you could have either a faulty Z axis motor or a faulty cable
    how is the motor connected to the cable from the control box ?
    if the motor has short tails of about 4" going to a 4 way connector with crimped terminals
    look very carefully to make sure the terminals are crimped to the wire and not the insulation
    (also check the cable )
    you can use a multimeter set to resistance to check the resistance of each motor coil and pair of wires back to the control box are equal
    if you measure one coil as 4 ohms and the other 7 ohms
    you have a high resistance joint to correct
    John
  1. Help! Mach 3 Won't Move my Stepper Motor - Emergency Stop Mode
    By AntonCNC in forum Machines running Mach Software
    Last Post: 03-08-2017, 02:38 AM
  2. Replies: 9
    Last Post: 12-29-2014, 05:36 AM
  3. New 3-phase steppers incredibly weak. Wont move machine
    By SwampDonkey in forum Tormach Personal CNC Mill
    Last Post: 05-25-2014, 04:53 PM
  4. Move driver to another motor under power?
    By boblon in forum Stepper Motors / Drives
    Last Post: 06-25-2011, 04:12 AM
  5. How to code a step motor axis move?
    By Niggo in forum OpenSource Software
    Last Post: 08-14-2007, 04:40 AM
