586,060 active members*
4,455 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Number of machining passes in Dolphin Wire EDM Module?
    Feb 2010
    112
    I was looking at the help file and noticed it listed a Roughing, and 2 trim passes. Is that an adjustable parameter if more passes are needed? I sometimes use 4 or 5 passes on my work so was curious.
    thanks,
    Ken
    Feb 2007
    413
    Re: Number of machining passes in Dolphin Wire EDM Module?
    Hello,
    The maximum number of passes per operation is 3, rough, middle and finish.
    However, you can copy n paste the operations to give 2 Goround commands, this will give a maximum of 6 passes. Paste again and this will allow up to 9 passes.
    You will need to set each pass to be active and have the offset you require. Although we call the passes rough, middle and finish they can in fact be any sort of pass, there is no intrinsic data associated with each pass, it's just what you set on each tab.
    Hope this helps
    Andre
    Feb 2010
    112
    Sure does, many thank Andre.
    May I ask you, Im trying to put in pilot hole references with notes, from the cad side, and want them to be visible on the cam side as well ,but im not getting it right. Help please!
    best regards,
    Ken
    Feb 2007
    413
    Hello Ken,
    You don't need to use the notes in CAD, this was the process some years ago but has been overtaken by other settings on the Goround dialogue box.
    But if you prefer, you can still use them in CAD as long at they go along with a corresponding "Start" note
    The format for the notes is $S1 for the start of the Contour and $P1 for the pilot hole (note that S & P are upper case)
    You won't see the note item in the EDM module but you will see a small blue triangle at the pilot hole position.
    If you don't use the notes in CAD you can use the Options tab on the Goround command to enter a pilot hole position relative to the start point on the contour.
    Andre
    Feb 2010
    112
    Thanks Andre, that worked. I was putting a note for the Pilot hole correctly, but not putting anything for the Start Position. Can a note be used at the end of an open profile to choose a point to lead off to?
    Thank you,
    Ken
  1. Displaying number of passes
    By dannirr in forum Tormach PathPilot™
    Last Post: 10-16-2017, 01:56 PM
  2. Number of passes on a lathe
    By juwyro in forum FeatureCAM CAD/CAM
    Last Post: 09-09-2017, 12:16 PM
  3. A new Module to engrave with 4 passes
    By sebmay in forum CamBam
    Last Post: 09-05-2016, 08:37 PM
  4. Baltic Birtch Number Of Passes
    By 2_many_hobbies in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-04-2014, 11:50 AM
  5. G76 Number of Passes
    By eliot15 in forum G-Code Programing
    Last Post: 04-09-2011, 12:51 AM
