586,069 active members*
3,554 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Operating help for Bridgeport 2216 with Fanuc 21i-M
    Aug 2012
    279
    Trying to get going on this mill and have only done a little with a simpler mill (Tormach). I was run through start up before but have incomplete notes. Was just trying to run a simple program to get started and ran into some issues before I hardly got started. Got the following errors:
    Machine not referenced
    Reference sw fault
    This is probably just something I am not doing. I found a Fanuc manual but things apparently can vary from machine to machine. Where can I find a manual or notes on operation? What do I need to do about these errors?
    Re: Operating help for Bridgeport 2216 with Fanuc 21i-M
    Jim, sorry I cannot help you with your problem but maybe you can help me with mine. I lost all parameters of my bridgeport and I do not have a backup, is it possible that you can send me a copy? You´ll be a great help. Mine also has fanuc 21i-M
    jolulank
    www.doctornumerico.com
    cnc physicians
    forgot my email just in case you can.
    [email protected]
    cnc physicians
    Quote Originally Posted by Jim27 View Post
    Reference sw fault
    So what you have to do every time you turn on the machine is home or reference each axis.this is done by moving each axis away from the reference position with jog mode and then pressing the home button and then +x, +y, and +z. The machine will home and then you can use it
  1. bridgeport VMC 600 30Digital 2001 Operating & Maintenance Manuals Needed
    By andy200470 in forum Machinery Manuals / Brochures
    Last Post: 03-20-2013, 12:08 AM
  2. Bridgeport VMC600 30 Digital 2001 Operating and Maintenance Manuals Needed
    By andy200470 in forum Bridgeport / Hardinge Mills
    Last Post: 03-19-2013, 11:58 PM
  3. Bridgeport Series 2 Interact 2: Need operating manual
    By R6.3 in forum Bridgeport / Hardinge Mills
    Last Post: 12-24-2012, 09:16 PM
  4. Fanuc series OI-M operating manual
    By homorenia in forum Fanuc
    Last Post: 06-13-2012, 08:33 PM
  5. Replies: 2
    Last Post: 11-22-2007, 03:17 AM
