586,060 active members*
4,323 visitors online*
Results 1 to 1 of 1
    KL-6590 36? x 25.6 ” with Spindle and Relay Control
    https://www.automationtechnologiesin...relay-control/
    This machine runs at 110VAC or 220VAC, We add a step-up transformer, 110VAc to 220VAC (Optional add $100)
    Brand New CNC Router Engraving Machine with USB Connection
    2.2KW (3HP) Liquid Cooled Spindle + 2.2KW Variable Frequency Driver
    We Changed this Machine to Mach3 Controlled System.
    Machine Size: 960 x 1320 x 1200 mm
    Working Size X,Y,Z : 650(x) 900 (y) 200mm(Z) ( about 25.6" x 36 " x 7.87")
    Gantry Height: 200mm (7,87 inch)
    Working Speed : 200 -300 IPM, Rapid Speed: 500 IPM
    Resolution: about 0.002"
    Mach3 Controller with Mach3 Demo Software (Mach3 License file is not included)
    Spindle: 2.2KW, Water-Cooled, ER20 collet chuck
    Water Pump With Tank
    Spindle Speed: 0-24000rpm with VFD, AC220V/50Hz/60HZ
    X, Y, Z axis driver: Stepper Motor Driver, NEMA34 Stepper Motor, 640 oz-in
    Y axis has Belt Reduction 1: 4.5 ration
    X, Y Z Limit Switch, E-Stop
    3 axis USB Breakout Board, you can use at 32, 64 bit computer, Window 10, 8, 7 , XP
    20 Taiwan Hiwin Rail and Guide
    Wood Packing Size: 1380 x 1090 x 1400 mm
    One year USA parts warranty
    Attached Thumbnails Attached Thumbnails KL-6590B.jpg   KL-6590A-150x150.jpg   KL-6590C-150x150.jpg   KL-6590D-150x150.jpg
  1. Spindle Relay Control with Mach3 and MX4660
    By icecats in forum Mach Software (ArtSoft software)
    Last Post: 06-06-2017, 12:29 PM
  2. Mach3 Spindle Control w/ Relay
    By kNucklBustr in forum X3/SX3/G0619/G0463
    Last Post: 02-01-2014, 06:12 PM
  3. X1 Spindle control relay installation (belt drive)
    By fragger6662000 in forum Benchtop Machines
    Last Post: 04-19-2010, 11:55 AM
  4. How to set a relay for a spindle motor ON/OFF control
    By TTaki in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-09-2005, 01:26 PM
