586,096 active members*
3,696 visitors online*
IndustryArena Forum > Other Machines > Commercial Products / Manufacturers Support Forums > Automation Technology Products > 4 Axis Stepper Motor CNC Router / Mill Electronics Kit, Gecko G540 (110VAC/220VAC)
Results 1 to 1 of 1
    Link:
    https://www.automationtechnologiesin...110vac-220vac/
    This is nearly plug and play --
    1: the only connections required are two wires between the G540 and power supply
    2: the AC power cord for the power supply, both of which are provided via convenient screw terminals.
    This kit includes:
    1: 1 pcs 48V 12.5A switching power supply (110VAC/220VAC)
    2: 1 pcs Gecko G540 4 axis stepper motor driver, Current Version
    3: 4 pcs High-torque Nema 23 1/4" shaft 381 oz-in stepper motors. These are optimized for the G540 at 3.5A current , KL23H2100-35-4B
    4: 4 pcs High-performance flexible, motor cables 12 feet cables. No soldering
    One side wired with BD9 connector, one side wired with motor plug
    One year warranty
    You can update to a USB or Ethernet Board
  1. Replies: 1
    Last Post: 03-22-2020, 07:40 PM
  2. Replies: 0
    Last Post: 01-19-2015, 10:37 PM
  3. 3 Axis CNC Stepper Control Box 110VAC/220VAC:
    By automationtechinc in forum For Sale Only
    Last Post: 01-17-2015, 09:20 PM
  4. 110vac or 220vac on a lathe and mill --- when given the choice????
    By State Variable in forum Benchtop Machines
    Last Post: 03-11-2013, 03:02 PM
  5. 110vac single to 220vac 3 phase VFDs
    By tootalew in forum Phase Converters
    Last Post: 09-26-2009, 02:33 AM
