586,061 active members*
4,414 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Machine limits reached or exceded
Results 1 to 6 of 6
    Nov 2006
    11
    I upgraded from version 25 to 30 and opened a Bobcad file into v30 that I had used several times in v25. I tried to simulate the program and it gave me a message that "the machine limits are reached and exceeded for: Second Tr. Axis(y) =-673.10(Min. -400.00)". I had saved the file in v30 so now, I couldn't use v25. So I'm stuck. Any suggestions how I could get v30 to work???
    Dec 2008
    4548
    Quote Originally Posted by jimbogrif View Post
    Extend the limits of the chosen machine.
    If you right click in the top of the cam tree and choose current settings, there you will find the machine definition.
    Clicking on and axis delimeter in the machine tree will open its parameters on the right side...
    The limits are there....
    You can set things to your actual machine, so the sim will help more than just a pretty picture.
    Nov 2006
    11
    Re: Machine limits reached or exceded
    I chose "current Settings" then "Machine Definition" and set the X&Y direction to +1, the X limits to -2 to 100 and the Y limits to -2 to 50. It still didn't simulate. I'm using Mach3.
    Nov 2006
    11
    Just started working - not sure what I did?
    Dec 2008
    4548
    So the machine setup in the cam tree has an "origin" for zero... your cut moves (axis travels) from there.
    You set your limits to 1 and 50? The error you posted shows numbers like 600!
    The new system takes full advantage of the machine definitions and cam tree machine setups and work offsets. The old 25 would just let you go to town...
    Take a slow pace through the setup. Think more in line with having to setup an actual machine.
    Dec 2008
    4548
    Could be you set things correct, but bbcd system needed a tickle to get those new settings into file?
    Hard to say...
    BobCad has always had 2 parts to its settings..
    Default settings and part settings. Default are global and part is current doc....
    Usually, global settings are read at startup. So makimg changes to global settings like the machine def, i would then restart the file, and do some re-selecting and re-computing just to be sure i was working off of the changed settings...
  1. Homing and Limits... new machine.
    By adam_m in forum DIY CNC Router Table Machines
    Last Post: 01-25-2014, 09:59 PM
  2. Setting up Config >Homing/Limits Dialog (Motor Home/Soft Limits)
    By CStevens6 in forum Mach Software (ArtSoft software)
    Last Post: 07-18-2013, 04:19 AM
  3. Machine Limits
    By pinguS in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-29-2011, 08:29 AM
  4. How to tell Mach3 machine limits ?
    By ringram2077 in forum Machines running Mach Software
    Last Post: 05-09-2007, 12:33 PM
