586,105 active members*
3,210 visitors online*
Results 1 to 7 of 7
    Feb 2018
    14
    FAnuc 18i auto reset programme
    Hello everyone
    We have a chiron with fanuc 18i controller, that auto reset the programme, it means that there's a programme processing and than suddently the programme stops and goes back to the start but machine dont move, it happend on all programmes, diffrent blocks, sometimes 3 or 4 times a day, sometimes 2 weeks without reset.
    What i did is that i changed the reset button, so i plan to change the keyboard, anyone has seen similar issue?
    Apr 2009
    1379
    Re: FAnuc 18i auto reset programme
    Interesting problem. Do you get any alarms?
    I suspect there is an intermittent machine input, such as limit switch, pressure switch that trigger this through the pmc.
    Can you look at the event history?
    Feb 2018
    14
    Intrresting but annoying, i changed the keyboard but no changes, there's no alarm in history, it just stop and reset itself, because it never happend in the same block or the same position it make things very hard to analyse, i'm lost dont know where to start
    Apr 2009
    1379
    I have never used it, but think that you can set trigger conditions to record upon an event. Without being there its hard to analyse. It could be a control issue, but can also come from the machine interface.
    Feb 2018
    14
    Never heard about the recording option, but that would ve useful, i cant think of anything but a cn issue, Those old machines makes ur life hard
    Apr 2009
    1379
    In the maintenance manual (630045) section1.6 OPERATION HISTORY.
    Feb 2018
    14
    Quote Originally Posted by memoryman View Post
    It happened again and I noticed something today, the program reset but the spindle continue to rotate!
  1. fanuc i reset
    By tpsimer in forum Fanuc
    Last Post: 08-24-2014, 03:43 PM
  2. auto reset problem in Mach3
    By kievari in forum Stepper Motors / Drives
    Last Post: 07-09-2012, 06:51 PM
  3. Axis won,t reset on Fanuc O-MC
    By AZDEN in forum Fanuc
    Last Post: 07-05-2011, 09:16 AM
  4. reset en auto d'un fanuc
    By skidoo in forum French
    Last Post: 03-09-2009, 01:15 PM
