Re: Which Spindle and VFD... again
Originally Posted by
mactec54
If you want to turn on the VFD from the G540 you would need a solid state relay like this suited for your supply ( 40A rated for the solid state ) or a contactor with a ( 30A rating ) you can switch something else with the contactor as you would have 2 spare contacts, so anything like in the snips
These are for switching your 240v supply to the VFD Drive R and T wires have to be switched for 240v NA supply
The switching voltage from the G540 would have to suit the solid state input and the switching coil of the ABB contactor
Perfect! exactly what I was looking for... Mactech54 also thanks Ericks.
Gecko G540, Rack and Pinion Drives-X and A axis, 1/2-10 5 Start Acme-Z Axis
4-THK HSR 25 Linear Slides, KL23H2100-35-4B, Power Supply-KL-600-48 48V
