The relay starts and stops the spindle, by connecting the FWD terminal to the DCM terminal.
Thanks Gerry.
I finished wiring up the spindle today and was successfully able to get it setup and running thanks to everyone's assistance. I shot a video of the initial setup (actually the second pass) and the tuning process and posted it on youtube for anyone else with a Huanyang GT VFD and similar spindle, hopefully someone finds it useful.
https://youtu.be/veYxrNNFgcA
As for the "Shield" since the router didn't provide a termination for the cable I some what cheated and I guess someone will tell me I'm crackers but I attached a short lead to the "shield" wire on the spindle side, shrink wrapped it and ran it out the top of the connector. I plan to attach this to the zplate that the spindle is mounted to and then again at the VFD to ground, other than the ground being used to power the spindle.
It did seem curious to me though that when I was manually adjusting the potentiometer it seemed to surpass the 18K rpm threshold. I'll need to make another pass at it to verify but was curious if that were possible and what would happen it was? I'm guessing that would be an incorrect frequency setup somehow in the FVD??
I guess there's only one real way to find out and that's to try it...
Many thanks for all the input on the subject, now onto wiring up Mach3 and the G540.
Adam,
Gecko G540, Rack and Pinion Drives-X and A axis, 1/2-10 5 Start Acme-Z Axis
4-THK HSR 25 Linear Slides, KL23H2100-35-4B, Power Supply-KL-600-48 48V
Well done....you making great progress
It should be wired to power on when you power up the machine, and down when you turn the machine off. You don't turn it on and off just when you want to run the spindle.
It will all depend on how you plan to make your control system. Best to turn the drive on when you power up your control panel. Mine is powered up a few seconds after i power up my control panel....i am using a 30A relay.
Sorry Gerry....i typed while you posted
So essentially drive it with a relay at startup...
is there a way to get the fan to come on when its actually hot and not always run... it sounds like a small aircraft powering up.
You don't really need a relay to power it. It can be powered to come on with the main supply too...
Your drive might have a parameter to "control" the internal fan. Mine does....otherwise i am sure someone have done a conversion on it already
Plugging and unplugging is not permitted, it is easy to damage the VFD Drive by doing this most manuals have this, you must have a industrial quality switch between the VFD and the Power Supply Can be a quality Switch or if you want to do it correctly use a MCSB snip below
AS for going over the 18,000 RPM how much over did it go over, this could be that the auto tune over estimated the slip compensation
Mactec54
The fan is to keep the electronics cool, some VFD Drives this is controlled by a thermistor meaning it will self regulate the speed to the amount of cooling it requires, some run all the time and have no control and some only run when the VFD Drive output is drawing current
You could use ( 1 ) of the built in relays to turn the fan on when the drive is running the spindle, but it may need some cooling while it is just sitting with the power on also, you would have to contact the manufacture to see if it needs continuous air flow
Turning a VFD Drive on and off will shorten the life of the drive
Your Grounding of the shield not ideal will not be a problem as your spindle will be away from any sensitive electronics that would be affected by any noise from a poor connection like this, connecting the Ground to the back plate will serve no purpose, it should all end at the spindle Ground and Shield Termination point
Mactec54
Thanks Mactec54, I'll take another cruise through the manual tonight and look specifically for the fan settings..
About the shield again... since I can't terminate the shield at the spindle plug I thought that at least I could use the backing plate as a return path since its ultimately grounded.. I guess that was a bad assumption. Should I just leave it totally ungrounded then?
Adam,
Unfortunately I'm not trained in electrical wiring and schematic interpretation which is why I'm hoping to gain some clarity from the forum users.
I did find the fan setting in the manual as you suggested. Can you answer this for me, the manual has options 0 and 1 which I understand but what is the additional information (Setting Range, Factory Setting, Modify, No.) used for, is it just informational?
Attachment 407616
This was my reply from Huanyang on a similar question, which I don't understand?
In reference to powering on /off the VFD. I plan on using a control panel that I have made that will turn on my G540 and the VFD at the same time. I think I need to use the voltage from the VFD to control a relay that will turn on the VFD, does that make sense? I'm assuming that for this to work I'll need to insert the SSR relay into the NEUTRAL "T" line of the power cord supplying the VFD with power?P8.26 in the case of 0, the S1 terminal and the COM terminal in the closed case, the power on will not work.In most cases, choose "0'.
Attachment 407618
Am I not thinking about this correctly?
It needs to be terminated at the spindle, the Back plate would only be Grounded if you had a Ground wire attached to it, there is not a good or true Ground Bonding through Bearings any unnecessary wires out side of the supply cable only act as an antenna for noise distribution
Mactec54
The added information for the Fan is for how long the fan stay on after it has turned off the spindle, they usually run for up to a minute a longer time won't hurt anything, the VFD will Fault if it over heats so you don't want that to happen
No, You don't switch a Neutral line if you have one
Is the Power you supply the VFD input 240v single Phase or 120v single Phase ??
Mactec54
Do you mean power up the VFD, or start the spindle? There should NOT be a relay to power the VFD.I think I need to use the voltage from the VFD to control a relay that will turn on the VFD, does that make sense? I'm assuming that for this to work I'll need to insert the SSR relay into the NEUTRAL "T" line of the power cord supplying the VFD with power?
And you don't have a "neutral" if the spindle is 240V.
Sorry Gerry that should have read the voltage from the G540 to power on the VFD.
My focus here is how to turn on the VFD with the G540 since I don’t have 1 power switch for my CNC I wanted to find a way to power up the VFD using the G540. Is that not possible?
No, you want the VFD to power up with your main power. As Mactec showed in post #170.
