I'm trying to disassemble my new SX3 to remove the grease. I've removed the bolts from the bearing support plate on the left and right ends of the table, and removed the plate from the left end. I can't separate the table from the motor on the right, however. If I pull hard enough on the table, I move the table with the motor (the ball screw turns along with the motor). Any suggestions? Thanks.
