Good morning,
I did my first machine relief using Artcam.
My cnc is homemade so it is not that much rigid and cannot go over 1250mm/min (50ipm)
I first did a 6mm roughing pass then did 2 mm ball nose pass for the finish. The material is poplar.
The settings were, 2 mm diameter, 1000 (40ipm) feed rate, stepover 0.2 mm and stepdown 0.5 mm. and it was 15000 rpm.
As you can see the surface finish is not even close to what it should be with scallops/waves and other problems.
Any ideas what I was doing wrong?
Thanks a lot in advance.
