586,067 active members*
4,961 visitors online*
    May 2010
    122
    MPG Selection
    What should I be looking for when selecting an MPG dongle? I'm using a Gecko G540 and Mach 3.
    I found 4 so far:
    https://www.youtube.com/watch?v=q7aLiMDHQrM
    https://www.youtube.com/watch?v=Z910AXJj8xo
    https://www.youtube.com/watch?v=oA_JDPKp3tI&t=8s
    https://www.youtube.com/watch?v=qTMDMipkZ5o&t=598s
    I'm leaning towards the Tormach knockoff 'Shuttle'. Main reason is, do you really need all those buttons that you see on the Chinese ones? Also I like the double wheel i.e. inner wheel is fine control, outer is rapid. I also like that it's on a cable. I don't really want wireless, recharging is the most annoying thing in the world I think. One question that comes to mind about it is on the Chinese ones, you have the Off position for the axes. Do MPGs generate pulses when a program is running? Do you really need the off position? There's obviously no off functionality on the Shuttle.
    May 2010
    122
    Re: MPG Selection
    Can't do advanced edit for some reason, so I'll post my edit to the post above here.
    I searched the forum for discussions on this issue but couldn't find any talk about MPG selection. Which is quite surprising! Maybe I searched wrong.
    Also, what's the dealio with resolution? Most steppers seem to only like 0.001, 0.010, 0.100 and 1.000 as the options. But I can't remember what the figure is off the top of my head, but I doubt my CNC machine can do distances like those. Well specifically I'm curious about the 0.001. I didn't come up with this problem, that's from 5:40 from the final video that I attached.
  1. Need to bypass Random selection/shortest path tool selection method
    By Tizbass in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-13-2012, 02:38 AM
  2. VFD Selection
    By AK_Five-O in forum Phase Converters
    Last Post: 01-30-2011, 02:16 AM
  3. Need help with saw selection
    By thedave in forum Uncategorised MetalWorking Machines
    Last Post: 11-19-2010, 06:44 PM
  4. TM6 vs TM8 selection Help
    By Kludge in forum HURCO
    Last Post: 06-11-2008, 02:31 PM
