586,110 active members*
3,173 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > looking for spindel air cooled advice
    Sep 2011
    21
    iam looking for what i should buy for air-cooled spindle looking to build guitar bodys and 110v
    Oct 2011
    477
    Re: looking for spindel air cooled advice
    I use the Tormach 24k water cooled spindle with chiller and power disconnect. Pricey BUT verrrrry good. You will find the water cooled significantly quieter than an air cooled because the fan is usually louder than the spindle itself. The cooling efficiency of the fan also drops as the cooling fins load with dust requiring cleaning.Added benefit is that it is fully integrated with PP and uses the existing VFD.The photos show cuts in exotic hardwoods using 1/16" and 1/32" carbide end mills both feed and spindle wide open. Step overs are in the range of 0.005" to 0.010". The horses requires about 24 +/- hours to cut. Finishes are good enough that no post processing like sanding (impossible at this detail level), polishing, etc. is required. Just shoot several thin coats of lacquer.gary
    Sep 2010
    56
    Geez Gary! That is beautiful work!
    Sep 2011
    21
    very nice work sir
  1. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  2. Air Cooled vs Water Cooled Pros and Cons and Advice
    By Tundraman in forum Spindles / VFD
    Last Post: 06-20-2015, 08:41 PM
  3. Replies: 0
    Last Post: 04-27-2014, 03:49 AM
  4. water cooled spindle vs air cooled
    By ken2010 in forum Chinese Machines
    Last Post: 10-21-2013, 06:03 PM
  5. Water Cooled Spindel
    By rosco in forum Chinese Machines
    Last Post: 02-11-2010, 02:28 PM
