I have a Crusader M Controller on a 3 axis cnc mill. When I program the Frame milling sequence with all the varibles needed in the program, everytime the Z feeds down to repeat the same pattern, the tool will move over in the X or Y at the same time. I have also had the machine go into a Z feed down when it is not called out in the program. I have had these issues with or without cutter comp, in rectangle patterns and in arc patterns. Any idea why? I have not yet completely ruled out that the operator may just be an idiot, but I've spent hours trying to sort it out and have ran out of ideas.
Kevin
