586,069 active members*
3,332 visitors online*
    Jan 2018
    22
    Anchors vs Carriage bolts
    I am crossing one 8020 3060 over the top of an 8020 3030 at 90 degrees. Is it stronger to use carriage bolts and U bolt plates or counterbores with anchors?
    bgasser
    Kansas City
    Re: Anchors vs Carriage bolts
    Hey thereBased on your 90 degrees arrangement, Counter bores with anchors is a better option. They are stronger than carriage bolts, Counter bores give room for such arrangement.
    Hey there
    Nov 2020
    Carriage Bolts (https://www.albanycountyfasteners.co...olts-s/281.htm) have their own strengths and they are good when you have to attach metal with metal or metal with wood.
    Here I prefer Concrete Anchors aka Strike Anchors (https://www.albanycountyfasteners.co...SLPAnchors.htm).
    Strike anchors or concrete anchors are used in applications including solid concrete. These are considered as an impact expansion type of anchor. Concrete anchors consist of four main parts, the body, drive pin, a nut, and a washer. The nut and washer are coated in yellow zinc. The body is made up of carbon steel and has an interior hole that is the entire length of the anchor. There are many types of concrete anchors available in the market. These include hammer-set anchors, lead screws anchors, anchor bolts, plastic wall plugs, and many others. These anchors are considered light-duty, medium-duty, or heavy-duty but that is based on how much weight these anchors can support.
  1. Boat Anchors hahaha! Light Machines CNC Lathe & Mill
    By Contract_Pilot in forum Benchtop Machines
    Last Post: 11-19-2016, 08:45 PM
  2. Replies: 0
    Last Post: 07-27-2013, 06:39 AM
  3. Press Brake for Pipe shoes and anchors
    By yinkaakins2001 in forum Want To Buy...Need help!
    Last Post: 11-13-2012, 07:57 AM
  4. Question about 80/20 and Carriage Bolts
    By Go-Go-Legoman in forum DIY CNC Router Table Machines
    Last Post: 11-30-2011, 12:58 AM
  5. Need dimensions for housing bolts (not mounting bolts)
    By rcpilot82 in forum Stepper Motors / Drives
    Last Post: 09-22-2011, 02:29 AM
