586,075 active members*
4,087 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Post method for Backing up the turret before long boring bar swings into place?
    Aug 2005
    124
    Guys (and Gals?) - I wondered if any of you are using a neat method in the post (the Post always remembers - unlike me) to back the turret up before swinging a long boring bar into place after running a short shank-type turning tool, in the same turret, has just run. You can imagine - we're 6 inches from the chuck and an 8" boring bar comes out. Yikes!
    The Lathe has a Mazak T32 control if that matters but its basically Fanuc G-code. I've tried using the boring bar offset with the stick tool, like T0826, but the boring bar's X offset gets used too and so, still it moves the leaving tool toward the chuck, because of course to get the tool tip of a large boring bar to the same point the stick tool tip is, you need to bring the turret slide way down, so the stick tool moves toward the chuck an unhealthy amount.
    Maybe the tool change unit can see, thru MasterCam, that the next tool is a boring bar and add 10" to the existing position? I appreciate the help!
    Dec 2013
    5717
    Re: Post method for Backing up the turret before long boring bar swings into place?
    Try a G53 in your code, this uses the machine coordinate system to move the carriage to an absolute position without the tool offsets applied. Cancel the G53 with a G54 after the tool change. I have the same problem with a long live tool, need to move the carriage way back for tool changes.
    G53 X0. Z0.
    T808
    G54
    Jim Dawson
    Sandy, Oregon, USA
  1. Boring hole pattern, takes a long long time
    By kvadda in forum Mach Software (ArtSoft software)
    Last Post: 03-23-2015, 10:03 PM
  2. Long Boring .600 diameter hole
    By avarouxis in forum Material Machining Solutions
    Last Post: 10-31-2013, 07:11 PM
  3. 5th axis help, trunion swings in both directions
    By houstonsamuel in forum Mastercam
    Last Post: 01-14-2011, 08:29 PM
  4. What is the best method for boring large holes in aluminium bar?
    By Blakelidge in forum Taig Mills / Lathes
    Last Post: 06-15-2009, 04:44 PM
  5. Business Decision - long read and very boring...sorry!
    By mxtras in forum Community Club House
    Last Post: 11-19-2006, 03:37 AM
