Does anyone have plans / pictures / info on build a simple injection moulding machine?
http://www.lindsaybks.com/dgjp/djgbk/inject/index.html
THIS IS A PRETTY GOOD BOOK. LOOK FOR ANOTHER BOOK ON THE SITE CALLED, " BUILD A PLASTIC INJECTION MOLDING ATTACHMENT FOR A DRILL PRESS". IT IS MORE UP TO DATE, WITH BETTER ELECTRONICS AND CONTROLS.
SCOTT
Thank,
They do not want to ship to me in South Africa. Any other options?
Looks like Amazon has it and I think they will ship almost anywhere.
http://www.amazon.com/Secrets-Buildi...6966231&sr=8-1
Here are pictures and a lot more:http://www.users.qwest.net/~kmaxon/p...d_mach_137.htm
Dennis
Place I used to work made up a couple of plastic injection presses using Harbor Freight Arbor presses and heating coils. Shot had to be loaded by hand but they were for prototype work (one off) Worked great to test small dies. We also made temporary (soft) tooling for Engineering to try out ideas. (Sometimes they worked!)
I see a lot of posts on the internet about the book "Build a Plastic Injection Molding Attachment for a Drill Press".
Has anyone ever actually seen one work?
Does this go beyond theoretical, or it is another project to sit in the corner when a functional roadblock comes up?
Can somebody here point me to how to make rubber o-ring. O - ring is not to big, the biggest one maybe 5 inch. Thanks.
I once worked for an electronics mfgr (since moved to Asia) who used one of those for prototype and short run work. It consisted of a heating coil and a plunger. It was mounted in either a drill press or an arbor press depending on shot size. Generally used there for knobs, cabinet trim and accessories. Worked good for runs up to 100 or so, but was usually used for building samples for sales crew to take around. If orders started coming in we started building a real die for one of the big presses.
Hi Bread_O
You could try Kevin at backyardengineer he has build a hobby molding machine
the drill press thing is a joke, it is ok to think this way if you were doing micro parts
http://www.backyardengineer.com/ProductPageStart.html
Mactec54
@SKHAT
hey thanks fot he book its really interesting
plastic mould
I found this video showing one in action:
[ame=http://www.youtube.com/watch?v=uD-kCf8amHk]Make Your Own Plastic Parts With This Injection Molding Machine - YouTube[/ame]
The company that made it is: LNS Technologies High Tech Products for Hobby, Edcucation and Business
Hi, I get this injection machine plans. Is similar to the Gingery machine.
I will try to build it but with some personal changes.
Here is the link:
MEGAUPLOAD - The leading online storage and file delivery service
