586,108 active members*
3,084 visitors online*
Results 1 to 9 of 9
    Aug 2016
    18
    Help with my Z raising during 3d carving
    HI guys. I've had a 4x8 Chinese machine for about 3 years now. I do a lot of 2d cutting and everything is spot on in that aspect. The only glitch is when I do 3d carving. I'll start a 3d carve and rough out and then start a finish pass. As the finish goes along the Z slowly rises to the point within 15 min into the cut it's no longer in contact with the model. The z is tight as well as the new belt. The bit isn't slipping and the collet is new. Everything is lubed as it should be and there is no binding. My thought was EMI but I've done everything possible i believe to assure that wasn't happening. Just replaced the spindle wiring with a foil and braided cable as well. It has an XHC controller running Mach 3 and seem to run great just till I get into the 3d and Z motion. Any input would be greatly appreciated.As always thank you in advance.
    Jan 2007
    626
    Re: Help with my Z raising during 3d carving
    Hi Kurt,
    Did the problem start after you replaced the spindle cable or before?
    When you say 'no binding' I assume , with no power ont ehstepeprs, that you can wind the axis up and down, by hand, freely?
    I'm not sure 'foil braiding' is the best to use. I have always used 'braided screen' cable...might be worth a look...
    Did you earth the screen at both ends? You are supposed to according to Danfoss. This is the only case where you do, as far a I know.
    Are your motor cables screened? Maybe the Z axis is being affected because it is the closest to the spindle cable?
    Where is your VFD mounted? In the control box or in its own box?
    These problems are tricky....All I can suggest change one thing at a time until you discover what the cause is....
    Steve
    Aug 2016
    18
    Ty for the reply Sterob. This has been from day 1 with just the 3d stuff. 95% of my stuff is 2d and there is no problem there at all. I replaced the spindle cable in hopes it would solve my problem. The spindle cable has both foil and braid. When I remove the belt the Z slides up and down smoothly.
    Aug 2016
    18
    Maybe a picture will help as well. As you can see it cruised right through the flat part but it seems to raise just a little on each pass once the Z action starts.
    Reduce the Z axis acceleration.
    Aug 2016
    18
    Ty ger21 I will try that now. It's set at 400 now. I'll cut it in half and see what it does.
    Aug 2016
    18
    No dice. Thanks for the advice though.
    Jun 2013
    1041
    Are those acceleration units metric or standard?
    Ben
    Sent from my HTC6525LVW using Tapatalk
    Aug 2016
    18
    Metric.
  1. Raising the Bar - ShopSabre CNC - NEW PRODUCT
    By ShopSabre CNC in forum News Announcements
    Last Post: 07-16-2014, 09:02 PM
  2. Z AXIS raising up
    By i_am_joe in forum Uncategorised WoodWorking Machines
    Last Post: 04-27-2012, 10:51 PM
  3. Raising up a vise
    By webgeek in forum MetalWork Discussion
    Last Post: 11-08-2010, 03:49 AM
  4. Raising Voltage from 12 to 24v
    By Marcvw79 in forum Hobbycnc (Products)
    Last Post: 03-11-2008, 11:29 PM
  5. Relief carving small detailed parts - V-carving from greyscale image
    By ALAN2525 in forum Uncategorised CAM Discussion
    Last Post: 02-12-2007, 12:01 AM
