586,067 active members*
4,722 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Chinese spindle and VFD
Page 1 of 2 12
Results 1 to 20 of 31
    Nov 2011
    51
    Have a problem I need some help with.
    Bought a chinese spindle and VFD 2.2Kw and have a voltage issue. Seems that voltage is leaking and when i touch my cnc table at time i get shocked. I tried running a ground wire from my outside ground rod to the table but as soon as I start the spindle it throws an error code.
    Any idea's
    Jan 2018
    44
    Re: Chinese spindle and VFD
    I have one also, it works great. Never had this problem but I'm willing to bet you wired it wrong. I would start by checking your voltage supply (can't imagine why this would cause a problem but why the heck not start with the simplest thing to check) and one set of input it output wires at a time triple check my connections.
    I can try to shoot you over a picture of how mine is wired if you think it will help. After you absolutely sure everything is connected correctly as the seller what they think. I know everyone here claims you have zero support when you but Chinese stuff but I find that to be untrue. They really want good ratings on whatever sir you purchased from. I have had steppers, 3D printer control board, once a 1500mm ballscrew replaced free of cost from different sellers. They want it to work for you so they can sell more!
    Post a picture of how you wired this thing and maybe some people can chime in with help!
    Nov 2011
    51
    yes please send a picture.
    Also when running full speed my VFD is only showing 1.6AMP does this seem right? I figured it would run higher that that being an 8 amp spindle.
    ericks Guest
    Quote Originally Posted by msdeltaguy View Post
    Any idea's
    This is a dangerous situation!!!
    ericks Guest
    Firstly you should never power up a device like this without having its earthing properly done. So you need to have the spindle motor earthed.....not through the machine frame or table...on the spindle motor.
    Best is to test your installation/connections before even powering up.....
    Do you have an Electrical tester handy??
    When just running, or when actually cutting?
    My 8 amp spindle shows about 1.0 -1.3 amps when it's not cutting.
    Jan 2018
    44
    Quote Originally Posted by ericks View Post
    No joke the manufacturer of mine said grounding is optional and that they routinely do not ground theirs in a video showing them running it groundless. I felt discouraged from using a ground.
    Mine is grounded so you should be able to copy my setup.
    I will send a picture of mine tonight after I get home from work later on this evening.
    24221
    Agree 100%, proper grounding and bonding should be carried out according to NEC/CEC, but just about all jurisdictions will specify the same.
    Al.
    Albert E.
    Nov 2011
    51
    I have a fluke T87 will this be sufficient ? If so tell me what I need to test. I just rewired my spindle like this. Mine was in a different order using pins 1,2,3
    U=Pin 1
    V=Pin 2
    W=Pin 3
    Nov 2011
    51
    With it wired up like stated below:
    U=Pin 1
    V=Pin 2
    W=Pin 3
    I just reconnected the earth ground to my table and when I hit run on the VFD i hear a pop from the spindle and the VFD goes into error for a few seconds and resets. when I disconnect the earth ground the spindle runs fine. Problem is im still getting set on fire when i touch my linear rails. its quite the shock
    YES YES i know this is dangerous and thats why im on here trying to figure out what the heck is going on. I have double checked and my VFD is grounded to earth ground from the 220v AC circuit
    Nov 2011
    51
    When cutting. when cutting with a 3/4 end mill under a decent load (hardwood with a .25inch pass depth) the highest ive seen it get is about 1.9amps @ 18k RPM. I would figure that it would jump up to 3-4 amps at least
    Jan 2018
    44
    Nov 2011
    51
    Thanks for the video but I have all that correct so far.
    Jan 2018
    44
    Ok sorry I know that all sounds obvious but it's good to check did you make sure the VFD is properly set? I had to check out some settings on mine. They were correct but the instructions were pretty specific to have them set a certain way.. I'm going to dig up that video.
    Here are the settings they sent me :
    Step 1: Set PD005 =400
    Step 2: Set PD004 =400
    Step 3: Set PD003 =400
    Step 4: Set PD072 =400
    PD144=3000
    Here is the video link:
    https://youtu.be/ZiBQ26rU-5g
    Nov 2011
    51
    Quote Originally Posted by KidKhaos View Post
    PD144=3000
    Yep. Ive checked the VFD several times. Everything runs super good but when i grab my CNC table in certain areas it will shock the hell out of me. Obviously the external spindle case is being energized with voltage and energizing my CNC table. This is super crazy
    ericks Guest
    U=Pin 1
    V=Pin 2
    W=Pin 3
    Great.....having the tester will help a great deal When you come online and you are at the machine i'll run you through the test procedure....
    Nov 2011
    51
    im ready its 4am here in Mississippi LOL
    ericks Guest
    Wow..... Okay, first thing to do is turn all power to machine off
    Then disconnect the cables on the drive....the ones going to the spindle motor. you may leave the earth cable connected to the drive but u...v..w mus be disconnected.
    ericks Guest
    We are going to do two tests.....
    1) Confirm that all three motor windings are present/connected properly
    2) Test for any shorts between the windings and the frame of the motor...
    ericks Guest
    Just to confirm....the spindle motor stays connected, only disconnect the cables U/V/W from the drive, you going to test these cables where they are disconnected. This way you testing from the start of the cable all the way to the motor and the motor itself.....all in one. ps......the fact that you heard a pop in the motor most likely is a sign that there is either a short, moisture or swopped cables/wires.
Page 1 of 2 12
  1. Replies: 3
    Last Post: 10-19-2018, 05:12 PM
  2. Chinese atc spindle
    By Jon.N.CNC in forum Spindles / VFD
    Last Post: 08-14-2017, 05:36 AM
  3. Mini Mill X2 Spindle Head + VFD + Chinese Spindle= custom!
    By diyengineer in forum Uncategorised MetalWorking Machines
    Last Post: 12-26-2016, 10:04 PM
  4. Chinese Spindle
    By paragon61 in forum Machinery Manuals / Brochures
    Last Post: 08-18-2015, 01:23 AM
  5. VFD for .8kW chinese spindle
    By _AR_ in forum Phase Converters
    Last Post: 01-22-2013, 08:26 PM
