I have one of those amazon chinese spindle/VFD combos 2.2Kw and was wondering what is needed to control on and off as well as spindle speed within flashcut CNC? I have the 2.5a micro cnc controller
This is an old thread but for those that don't know a VFD Drive can only be used for a AC 3 Phase motor
Is your intension to just run the spindle as your VFD can not give you 3Phase power to run anything else, it can only be used to run a AC 3 Phase motor 7.5Kw is also to big for any normal Home Power service
Mactec54
Or, nobody using Flashcut has seen this....
Not sure if there are many Flashcut users here. I don't here it mentioned very often.
You need the mini io board and version 4.5 I believe.
