586,108 active members*
3,059 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Low cost/free CAM solution for 3D relief
Results 1 to 6 of 6
    Jan 2018
    44
    I am just trying to reach out to some of you veterans out there for a little advice.
    I built myself this here CNC router gadget.
    Here is a picture when she was almost completed.
    I am using an Arduino knockoff burned with GRBL to decipher G-code, mainly through UGS. Sometimes I run easel just to get the party started but as you know it is very limited. I typically use Fusion 360 for CAD/CAM, which works splendidly.
    I have recently had the hankerin' to cut some 3D reliefs with little success. I have tried using MeshCAM since it seems to be geared toward this sort of thing. I have an STL file I bought to try to cut to the chase a bit but haven't been able to use it in Fusion or MeshCAM.
    Fusion simply cannot handle it, the file is much too large. If I reduce it it loses most of its detail and Fusion still struggles to create a toolpath even if I were interested in using it afterward. The file starts out at about 3.6 million facets and Fusion will only convert about 50,000 facets into a solid.
    I can load the STL into MeshCAM, but never end up with a working toolpath. I honestly haven't gotten a single working toolpath out of MeshCAM in any scenario. I feel like MeshCAM is meant to be a more user friendly program than Fusion but that has not been the case for me.
    Feel free to drop any comments about your experiences here. I would love any advice about the current programs I am using, suggested software, ect. I would prefer free but would definitely consider paying for one if I felt it had value. I am not going to spend thousands... I know there is a better answer out there.
    As always any help is greatly appreciated... thank you in advance!
    May 2005
    73
    Re: Low cost/free CAM solution for 3D relief
    i use rhino 5 can you post the file mastercam normally handles most things it must be a problem with the stl file so need to have a look at it to help her is sum of my work so i am not just after the file https://www.thingiverse.com/davedpot/designs
    Feb 2010
    62
    Try DeskProto, it can handle even very large STL files without any problem. It is easy to use, and the basic edition is completely free. See www.deskproto.com/products/free-ed.php
    (this message comes from the manufacturers of DeskProto).
    Aug 2012
    181
    I also suggest Deskproto. Detailed meshes like reliefs are where it really is shines. CAM software for technical parts (like Fusion360) usually can't handle this properly.
    It doesn't get much easier than MeshCAM, so I'm guessing you are doing something wrong? Can you be more specific in your process, and what isn't working?
    Multi-million polygon models can take a very long time when creating toolpaths, especially on a low powered PC. With the wrong settings, it can appear that the CAM program is frozen, or non responsive.
    Aug 2012
    181
    That sounds like like a UX-bug in the CAM not communicating clearly that it is working and what it is working on. (Plus ability to Pause, Abort and maybe a progress).
  1. FREE 3D bas relief patterns for CNC!
    By iseovodoia in forum News Announcements
    Last Post: 03-25-2016, 08:48 AM
  2. FREE 3D bas relief patterns for CNC!!!
    By quazga in forum News Announcements
    Last Post: 10-28-2014, 09:32 PM
  3. LOW COST BEST QUALITY LARGE RELIEF MODELS
    By Khalid in forum ArtCam Pro
    Last Post: 07-25-2012, 10:30 AM
  4. NEW FREE 3D BAS RELIEF!!!
    Last Post: 04-02-2012, 04:38 AM
  5. Low Cost Chiller Solution
    By firejoe911 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-21-2009, 06:26 PM
