JobShopQuotes MAC is not just another estimating software
JobShopQuotes works on Real World manufacturing process and arrives at the estimate of the component in the way how it will be processed during manufacturing.
Our methodology works on Set-up based process and every set-up has its individual operations. JobShopQuotes suits to your unique working style where you have accurate time and cost estimates of your manufacturing.
Analyse the Estimates with respect to Quantity, Selling Price, Profit Margins or Profit Amount
What does JobShopQuotes MAC Cover
Being Machining Estimating Software JobShopQuotes if fully capable of giving accurate time estimates as below:
Raw Material Inputs covers calculations of
Bar Stock : Round, Square, Rectangle, Hex
Casting/Forging : Per Pc.
Pipe : Round, Square, Rectangle
Profiles: I Beam, C-Channel, Angle
Set-up Covers cost Calculations
Machines Covered are
Turning : Lathe, Multi Slide, Sub spindle. Turn-mill
Milling : VMC, HMC, Boring etc.
Drilling : All Drilling
Grinding : Surface, Circular
Planer : Shaping, Planer
Sawing : Bandsaw, Hacksaw
Apart from above you can add setup with respect to Time, Weight, Area, Volume, Length, Batch and Per Piece requirements.
This makes JobShopQuotes the most versatile software available today for machined components estimation applications.
Machining Operations Covers time calculations of
Turning: Facing, Face Grooving, Grooving, Parting, Internal Turning, Threading (Internal/External), Profile Turning (Internal/External), Turning (Internal/External), Taper Turning (Internal/External), Knurling, Burnishing
Milling: Face Milling, End Milling, Slot, Profile, Pocket (Square/Round), Boss (Square/Round)
Hole : Drilling, Boring, Reaming, Tapping, Burnishing
Grinding : Surface, Circular (external/Internal)
Planer : Shaping ,Planer
Download the trial version from website Part Machining Cost and Time Estimation Software for Machine Shop and Job Shops - JobShopQuotes MAC
