586,111 active members*
3,617 visitors online*
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Jul 2016
    660
    Re: Need Programming help
    Shoot you back an email
    Choose which one you like to drive a stepper driver + stepper motor
  2. #22
    Oct 2006
    37
    [QUOTE=KH0UJ;2190850]Shoot you back an email
    I have an Arduino UNO, Leadshine AM882 Digital Stepper driver, and here is a picture of my two motors. Thanks
  3. #23
    Jul 2016
    660
    Ok sir that will do so let me summarize what you want basing on your video and your control box with switches, you want the steppers to have an RPM counter, a forward reverse switch on the steppers in conjunction with the counter (+/-) you want to control the speed of the rotation from 0-1000 RPM thru a potentiometer, the counter must be subtracting the RPM counter display output if you set the machine in reverse mode. is this correct? anything else you wanna add sir?
    I will start coding this after work today
    on my opinion your RPM counter must be an independent module, your arduino will just be a plain stepper driver.
  4. #24
    Oct 2006
    37
    Quote Originally Posted by KH0UJ View Post
    I want the display to count revolutions. For example if I have 500 on the display. I want to turn the switch on, (the switch on the top left side of the box). then the motors will turn 500 turns and then shut off.
  5. #25
    Oct 2006
    37
    Well thanks to hfjbuis, my Arduino programming is complete. Many emails back and forth with little test programs.
    here is a little video explaining how it works
    https://www.youtube.com/watch?v=X-Tk4Hy7qtk&t=14s
Page 2 of 2 12
  1. Programming for HMC
    By Ashish B in forum Uncategorised CAM Discussion
    Last Post: 08-14-2014, 02:21 AM
  2. Xilog 3 Parametric Programming Offline Programming
    By julioykaly in forum Commercial CNC Wood Routers
    Last Post: 04-27-2013, 09:22 PM
  3. cnc programming
    By ADELWEIS in forum Employment Opportunity
    Last Post: 09-04-2009, 03:08 PM
  4. TL2.... programming
    By LorenzoNH in forum Haas Lathes
    Last Post: 04-13-2008, 06:54 PM
  5. Programming
    By chakaloso in forum Haas Mills
    Last Post: 03-07-2007, 11:34 PM
