586,036 active members*
3,576 visitors online*
    Feb 2011
    353
    DAEWOO LYNX 210A
    I am looking into cycle time reduction
    fanuc oi-tb control
    lynx 210a 2004 date of manufacture
    does anyone have anyway to get the machine out of the cut and back into the cut faster ?
    m31( interlock bypass - spindle rotation) not sure how it's used
    I have tried G0X0Z.1M3S1500M31
    The spindle doesn't start ?
    is this model or non model ?
    the sheet that i have has no m code to cancel for it so i assumed it is non model
    M60 (tool change with axis moving ) again how is it used and what precautions are needed to use this ?
    2932
    Re: DAEWOO LYNX 210A
    Do you stop the spindle at the end of each tool segment? If so, why?
    Please post a sample program so we can try and help.
    Feb 2011
    353
    I leave the spindle running thru the tool changes ( the spindle needs to reach 90% of the programmed rpm before it moves)
    some rpm changes are small some are large variations. so there will be a little cycle time reduction but i would like the savings from having the having the spindle ramp up/down while moving
    the one i am more interested in is the M60 (tool change with axis moving )
    the okuma's have a call out that allows the turret to be unclamped during the return to index point, then it indexes, then it clamps on the return to the start of the cutting point (when a g1 is entered on the next line the turret will not move if the turret hasn't finished clamping ) This saves about 2 second per index
    i believe the haas machines will do the same ( not positive)
    This program returns only in the z as there is room for indexing in the z
    there are some where i need to move in the x axis also this is where i use g28 u0.w0. to send it back to the reference point for indexing
    M53
    G54
    G50S3500
    G0G90G40G97
    N1
    (ROUGH TURN)
    (DNMG332)
    G28U0.W0.
    G97M3S1500T0101
    M8
    G0X1.Z.1
    G96S400
    G1X.925Z0.F.06
    X-.1F.005
    Z.05F.06
    G97
    G53Z16.5
    M9
    /M01
    N3
    (FINISH TURN)
    (VNMG321)
    G53Z16.5
    G97M3S1245T0303
    M8
    G0X1.Z.1
    G96S300
    G1X.35Z.05F.06
    Z0.F.004
    G1X.7425,R.077
    G1Z-.265
    X.826Z-.335
    Z-1.766F.007
    X.755Z-1.826F.002
    Z-1.938
    X.800
    X.840Z-1.958
    Z-2.135
    X.915Z-2.215
    G0X1.5Z.1
    G97
    G53Z16.5
    M9
    /M01
    N4
    (ISCAR DRILL)
    (.344 DIA)
    G53Z16.5
    G97T0404M3S3000
    M8
    G00X0Z.250
    Z.05
    G1Z-1.325F.006
    G0Z1.000
    M9
    G53Z16.5
    /M1
    N10
    (FETTE THREADING HEAD)
    (TOUCH OFF OPENED TOOL)
    (ROLLS 7/8-14 THREAD)
    G53Z16.5
    G97M3S750T1010
    M8
    G0X0.Z1.
    Z.25
    G32Z-2.200F.07
    G4U1.
    G0Z1.000
    G53Z16.5
    M9
    /M01
    N6
    (7/32 PARABOLIC DRILL)
    (.218 DIA)
    G53Z16.5
    G97T0606M3S2400
    M8
    G0X0.0Z.250
    G1Z-1.250F.050
    G1Z-2.000F.003
    G0Z1.000
    M9
    G53Z16.5
    /M1
    N8
    (FINISH ID REAMER)
    G53Z16.5
    G97T0808S725M3
    G0X0.0Z.250M8
    G1Z-.750F.050
    G1Z-1.800F.008
    G1Z-2.190F.006
    G0Z.250
    G0Z-2.140
    G1Z-2.225F.004
    G0Z1.000
    M9
    M5
    G28U0.W0.
    M52
    M30
    i was also thinking about a tool index macro that would index when the tooling clears in the x/z axis
    2932
    You might check prm #3708 bit 0 (SAR). If it's set to 1, then it will wait for the spindle to reach speed. If set to 0, it won't.
  1. DeaWoo Lynx 210A Setup
    By Tom214moto in forum Daewoo/Doosan
    Last Post: 12-26-2012, 11:17 PM
  2. (HELP) DAEWOO LYNX 200
    By lildave26 in forum Daewoo/Doosan
    Last Post: 06-29-2011, 11:40 AM
  3. daewoo lynx 200 (help)
    Last Post: 03-09-2011, 04:47 AM
  4. Daewoo Lynx 200b
    By atscnc in forum Daewoo/Doosan
    Last Post: 03-23-2008, 06:28 PM
  5. DaeWoo Lynx 200 GL
    By fjd in forum Daewoo/Doosan
    Last Post: 10-30-2005, 03:43 AM
