586,080 active members*
3,485 visitors online*
IndustryArena Forum > CNC Electronics > SmoothStepper Motion Control > What determines how a Stepper is wired
    Jan 2007
    626
    Trying to get my head around the 2 modes of Stepper wiring, 'Differential' and 'Single End'
    I know the differences in the way they are wired, but what determines which mode you choose?
    BOB is MB2 and stepperdrivers are YOC556 ( I can't find a manul for this particular Motor Driver. )
    I know the MB2 can use either mode. Doe the motor Driver have to be compatible to use a particular mode?
    The Stepper itself as well?
    Steppers are 57BYGH76-3A/150N.cm on a X61500GT CNC Router.
    I'm using sheilded cable but the pairs are NOT twisted as far as I know.
    Steve
Name:	MB2 Stepper Connections.JPG
    Nov 2012
    1267
    Re: What determines how a Stepper is wired
    Differential mode is more noise resistant and therefore should be used whenever possible (that is, if both the breakout board and the motor driver support it).
    The steppers themselves do not matter.
    Twisted pair is better, but a non-twisted shielded cable would work too.
    Jan 2007
    626
    Quote Originally Posted by CitizenOfDreams View Post
    Thanks, I guess I have to find out of the YOC556's suport Differential Mode or not.
    I found a manual for the M556GT which is supposed to be an equivalent. Will check it out.
    Steve
    Jan 2007
    626
    I found the problem.
    My Steppers were driving a short distance and then stopping. The same in the other direction.Every press of the jog key produced the same results.
    It turned out that some lucirious figures had appeared in the motor tuning window in Mach 3. I don't understand how.
    They must have been stalling after a short time, but I could not tell.
    I put the original steps, speed and acceleration figures back in and it all works fine.
    The steppers seem to run alot quieter now.than when the AKZ250 was fitted......very happy.
    Wired in Differential mode as well.
    Steve
  1. What determines available router cutting area size, besides physical design?
    By MajorTendonitis in forum DIY CNC Router Table Machines
    Last Post: 04-04-2017, 01:08 AM
  2. Replies: 5
    Last Post: 02-02-2016, 03:01 PM
  3. What determines the materials a machine can cut/mill? (aluminum specifically)
    By Thermodynamics in forum Uncategorised MetalWorking Machines
    Last Post: 07-27-2011, 02:09 PM
  4. Can someone explain what determines the price of cad and cam software?
    By slashmaster in forum Uncategorised CAM Discussion
    Last Post: 04-10-2009, 09:00 AM
  5. 10 wired stepper
    By smoregrava in forum Stepper Motors / Drives
    Last Post: 10-17-2005, 01:40 PM
