Hi guys, I have an electronic divider and want to hook it up to my lathe spindle so I can set work in the headstock and use the lathe spindle for divisions with a milling or wheel cutting attachement setup in the crossslide.
My intention is to use a setup similar to the attached picture. This is NOT my picture but will be exactly the sort of setup I am looking at.Attachment 395244
This uses a 10:1 timing belt but with 400 steps per rev on the stepper motor, that’s only 4000 steps per revolution and an accuracy of 360/4000 = 0.09 deg per step. Now that seems pretty damn good to me but I currently have the same divider attached to a rotary table with a 90:1 worm wheel reduction, giving: 400 steps x 90 = 36000 steps per rev. So 360/36000 = 0.01 deg per step!
I know for a fact this setup works really really well and is super accurate for my clockmaking. So I have been advised to use a geared stepper motor along with a timing belt. Although I have experience hooking up stepper drivers to motors and can do this, Ive no experience with these geared motors. Is there anything I need to consider and does anyone have any recommendations (ideally uk supplier) for a suitable geared stepper and drive belt combo? Does anyone have any thoughts on needing the 90:1 higher resolution or will the 10:1 resolution be acceptable?
Any opinions, thoughts or sources of geared steppers would be appreciated!
Chris
