I recently purchased a used 2004 sharp SV-2412, its not under power and the batteries that backup the parameters both died (they were 6 years old). Now the control is showing an alarm "100 Parameter write enable." Does the alarm suggest that all parameters are lost? I looked through the parameter pages and almost everything is set at 0 or just an *. If the parameters are lost is there a way to recover without having to manually input them all back in? The control is the oi mate-mb. Any advice would be appreciated!
The machine has funuc io mate interface ,and the drive ect. are funuc (ao 2b-2301-b801) (ao6b-6134-h303#a)
Can I use the rs232 port to import the parameters to the machine ,without manually putting them in,,and what software do I need to communicate with the machine.
