586,062 active members*
4,524 visitors online*
IndustryArena Forum > MetalWorking Machines > Sharp CNC > Help! I think I lost all my parameters...
    I recently purchased a used 2004 sharp SV-2412, its not under power and the batteries that backup the parameters both died (they were 6 years old). Now the control is showing an alarm "100 Parameter write enable." Does the alarm suggest that all parameters are lost? I looked through the parameter pages and almost everything is set at 0 or just an *. If the parameters are lost is there a way to recover without having to manually input them all back in? The control is the oi mate-mb. Any advice would be appreciated!
    Re: Help! I think I lost all my parameters...
    Go thru all parameters and check if actually they are all zeroes or not. The 100 alarm is just telling you that the control is enabled to change parameters and it has to be turned off at some point.
    If in fact you lostthe parametersyou need to get a copy of them with the machine builder or maybe there is a copy within your manuals or inside the machine. If the parameters are not lost then you have to do a procedure to send the machine home.
    If you want to write back please use my email [email protected]
    Best regards
    jolulank
    www.doctornumerico.com
    cnc physicians
    Feb 2013
    16
    I have a backup of SV-2412 parameters if you need them, though given these alarms you listed, you still might not need them.
    PM me if you did in fact dump them all.
    On another note, did your user manual explain how to reset machine zero position?
    Mine won't go to the correct home and my manual doesn't show the procedure.
    Good Luck
    Ken Shinn
    Quote Originally Posted by roofis27 View Post
    Good Luck
    Ken Shinn
    I found a procedure online for the zero reset. But i'm unsure of how to properly set the z axis to a proper tool change height.
  1. TNC 360 parameters lost
    By Fætteren in forum Controller & Computer Solutions
    Last Post: 10-10-2012, 08:50 AM
  2. Lost parameters
    By F_Alzaga in forum Want To Buy...Need help!
    Last Post: 11-03-2010, 01:32 AM
  3. Lost parameters
    By darrylh in forum Fanuc
    Last Post: 06-09-2010, 08:02 PM
  4. Lost parameters
    By alfonsosti in forum Okuma
    Last Post: 12-16-2008, 03:40 PM
  5. Lost parameters on 10T
    By ktb100 in forum Fanuc
    Last Post: 03-29-2007, 06:38 PM
