586,113 active members*
3,338 visitors online*
IndustryArena Forum > CAM Software > Surfcam > ncEdit quit working
    Apr 2007
    Post ncEdit quit working
    My surfcam editor quit working. This was caused by an update to windows. I uninstalled the last 5 updates and it started to work again.
    Aug 2006
    259
    yea happened to me too, on a couple programs.. if the error you were recieving was this:
    The system DLL user32.dll was relocated in memory. The application will not run properly. The relocation occurred because the DLL C:\Windows\System32\Hhctrl.ocx occupied an address range reserved for Windows system DLLs. The vendor supplying the DLL should be contacted for a new DLL.
    then do this hotfix
    hth
    Apr 2007
    Smile Worked Great
    The hotfix worked great Thanks
    Jun 2007
    Solidworks 2007 to surfcam 2004
  1. 6M quit tool changing
    By Drew in forum Fanuc
    Last Post: 01-23-2007, 07:32 PM
  2. Help on import, radio button quit!!!
    By XYZ machine in forum GibbsCAM
    Last Post: 01-11-2007, 10:24 PM
  3. Spindle quit running w/ c axix fault
    By TomCNC88 in forum Fadal
    Last Post: 07-28-2006, 04:07 PM
  4. BP Boss 5, Z-axis quit, help me please!
    By rsr911 in forum Bridgeport / Hardinge Mills
    Last Post: 12-20-2005, 06:29 AM
