586,076 active members*
3,893 visitors online*
Thread: fiber or co2
    Jun 2018
    fiber or co2
    Hi! I need little help to decide what i gonna buy. If you think that you can get same price 6kw co2(brand1) and fiber(brand2). Worlds top manufactures both. I need cutting quality be very good at thick materials 20-30mm. I heard that fiber edge quality sucks at over 20mm? Does anyone have pictures about thick material edge quality(fiber). Let me know if you think that fiber is overrated or best you can get. sorry about bad english
    Jul 2016
    660
    Re: fiber or co2
    On my opinion Hi-watt CO2 is still slow on cutting metals compared to a Hi-watt fiber, plus the fiber only uses hi voltage, so there`s no depletion, on the other hand the CO2 keeps on getting slower and slower in the long run because of gas depletion, plus fiber is cheaper compared to CO2, a simple buffing process on the edges would`nt hurt if you are worried about it, bottom line is the fiber is faster and more consistent type of machine.
    Apr 2013
    30
    Re: fiber or co2
    If both cost the same, Fiber is the way to go! It will end up saving you in the long run due to energy effficiency and continuous maintainance. Now, that is only my opinion and only directly related to question about the 2 options that you’ve presented. A friend of mine owns 1x 10kW Bystronic Fiber and 2x 6kW CO2 lasers...however, he uses all of his lasers to process all metal that is under 15mm thickness...he purchased a separate Hypertherm HD plasma based CNC for all of his heavy duty thick metal plate cutting needs. He loves it! Almost better edge finish than his lasers. Your call!
    Feb 2012
    387
    Re: fiber or co2
    depends on what you cut
    the fiber is much fasster https://youtu.be/2UGe76m4HWs
    Quote Originally Posted by Henkkali View Post
    Lucy Lee G.WEIKE LASER
    [email protected]
  1. Aligning Fiber coupler (Fiber collimator)
    By Ralphxyz in forum Laser Hardware
    Last Post: 12-08-2017, 08:24 PM
  2. CO2 or fiber
    By ic1uc1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-31-2017, 12:41 AM
  3. Replies: 0
    Last Post: 03-28-2016, 05:39 AM
  4. AK10F- A Portable Fiber Laser Marking Machine for Plastic, Fiber and Metal Engineerin
    By aaronhernandez in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-29-2016, 05:35 PM
